Results 1 to 15 of 23
Thread: 85 Big Red - Brake Job issue
    Minnesota
    26
    Got the new brake pads on fine but now I compressed the pads as much as i can see and I cannot put the brake drum back on.
    Any tips?
    Pics here, note the old pad :-)
    Jan 2005
    RI
    2,530
    sometimes a lip gets worn in the drum where the pads dont ride. how close is it to fitting? you may have to sand/grind out that little 1/8" lip to get it to slide over...
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jun 2006
    Willow, Alaska
    1,337
    Also make sure you have both brake cables adjusted out all the way. Clean up the inside of the drum too, the brake dust and mud/dirt/water can easily build up in there.
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Mar 2007
    Texas
    5,045
    i see there's a little bit of an angle on the expanding peice. it needs to be perfectly centered, that usually means removeing the rear adjusting nut and letting the lever fall freely. once you get the drum on, you should then be able to out the cables back on.
    ________________
    https://www.mikesatvfix.com
    Minnesota
    26
    Quote Originally Posted by oscarmayer View Post
    Thanks Oscar.
    Do you mean unscrew the top adjustment all the way and make that expanding piece straight?
    Thanks
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by walleyedude View Post
    Thanks Oscar.
    Thanks
    yep, that is what should work.
    Howdy
    Mar 2007
    Texas
    5,045
    ^ see great minds think alike.
    yea i know my techy lingo for this stuff isn;t up to par "yet" but i try to espain what I'm talking abotu so ya'll understand a little easier. now if this were computers, hey I'm right there! I'm a server geek by trade.
    ________________
    Minnesota
    26
    Thanks Guys, I will finish this job in a couple days.
    It is 10 below zero tonite!!
    Mar 2007
    Texas
    5,045
    skrdy cat! :P no pain, no gain!!!
    ________________
    CENTRAL NY
    1,709
    You might wanna take that expanding preice out and clean it good and put a little grease on it while your at it... they get crudded up and tend to hag up in the backing plate and not allow it to return...
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    SCRAMCHARGER318 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2008
    byron center
    154
    also make sure you grind a tapered edge where the end of the shoes meet the metal backing, if you don't it might catch on the drum and might make the brakes lockup, that is striaght out of my clymer manual. i also do that whenever i do drum brakes on anything cars,trucks,atv's. it will also make the drum go on easier.
    Sep 2008
    byron center
    154
    oh and make sure you get some brake lubricant and grease the backing plate where the shoes meet it, and the brake cam.
    Mar 2007
    Texas
    5,045
    oh and wear gloves to keep your hands clean.
    and use brake cleaner ont carb cleaner. carb cleaner has a very slight amount of oil where brake cleanrer does not.
    :P
    ________________
    Jonpin's Avatar
    Jonpin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Melbourne Florida
    333
    is it just me or does it seem like every time you take a big red out you need to over haul the brakes i got mine working great took it out a couple times and now there basicly worthless .there eaither locked up or going to the ground with slack ,im going to try scramcharger318's advise and see what happens ,i need my bike up to par for christmas going out for 3 to 4 days with it
    05 Kingquad 700 85 200x 85 250es 85 350x
    85 350x rider project 85 350x (project) watch the progress here http://3wheelerworldforums.com/showthread.php?t=85959
    Goin to prove you can polish a turd "so far it takes a lot of cash to buff that brown out'
    NE Arkansas
    2,344
    I put new pads and brake work on mine about 2 years ago. I have yet to even re-adjust them. If you clean em up good and all the seals are good, they last. On the other hand, mine never sees mud or water, I use the others for that, hehe.
    My Rags
