I got a 85 200x and I am having two problems:
1) The engine starts and runs awesome, but whenever it is running there is a loud ticking noise that can be heard over the exhaust. Anyone have a clue what this is and how to fix it?
I'd adjust the valves but if it's still noisy it's the timing chain and guides. Available at Dennis Kirk in a kit that seems to work well with a DID chain.... It also gives you a chance to clean and inspect the oil pump.
2) My rear brake caliper is leaking. don't really have the money now to get a rebuild kit. anyone see a problem with using the parking brake lever as my brake?
Go ahead and use it, it will be working similar to a Blaster manual caliper. But, I'd take the mechanism apart and grease it as they seize up often. Remember that if your caliper is leaking out, then it's letting garbage in too..........
