Thread: 225 motor in 200 frame?
    Aug 2007
    Granite Falls, Washington, United States
    8
    i am just wondering if a 225 motor will swap with my 200 tri moto engine? I am starting to rebuild my 1985 tri moto 200 and wondering if i should rebuild the 200 or just find a 225 engine.
    also if you have any favorite sites to buy parts from for 3 wheelers!?
    thanks
    adam
    Dec 2005
    Wisconsin
    1,141
    rebuild the 200 with a wiseco piston and a webcams cam shaft. the 200 will take any 225 and you won't have to chop up the frame.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Aug 2007
    8
    so the 225 is less power then the 200? I thought the 225 would just slid in the 200 frame, is that not the case? where do you buy your parts for your 200?
    Derek's Avatar
    Derek is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2006
    Boston NY
    164
    The 225 motor is shaft drive most 200 are chain well unless you have a shaft 200 then its a good possibility a 225 motor will work
    1985 Honda 200x
    - 30mm Carb
    - DG Exhaust
    - Rear Wheel Spacers
    - K & N Filter
    Apr 2004
    Brigham, Québec, Canada
    1,529
    The 225 is more powerful than a 200, but I think what wikid mean is that if you rebuilt your engine and put some performance parts it will be easier than buy a new engine and install it in the frame. But like I pointed in your other post, it seems that the 225 will bolt in the 200e frame.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
