Results 46 to 51 of 51
Thread: OK, Tecate guys New questions post #16. Splitting cases? Changing bearings and seals?
  1. #46
    NE Indiana
    1,067
    Quote Originally Posted by nd4speed View Post
    List of Polaris rear sprockets that fit and usually on ebay cheap:
    http://www.3wheelerworldforums.com/s...t=60994&page=4
    Just saw a discussion about this and they were suggesting something like up 2 in the front or down 6 in the rear.
    thank you!
  2. #47
    NE Indiana
    1,067
    Quote Originally Posted by cr480r View Post
    I would use a bearing puller on a slide to remove them, and use the hot/cold technique in combination with a and brass drift to install them
    I just happened to think about this one. When i install the crank bearings, do i install them onto the crank or put them in the cases and then put the cases back together and that forces the bearings on the crank? Because when i got the cases apart, the crank bearings are stuck on the crank itself. So, I'm not sure where to install the new crank bearings.
  3. #48
    Sep 2005
    MICHIGAN
    2,027
    bearings in case.
    does it look like bearings were spinning in case?
    That's why I said freeze crank for easier assembly.
    86 T3
    84 T3
    86 KX250
  4. #49
    Sep 2006
    Northwest Indiana
    1,893
    You either have to borrow the tool, or take the crank to a motorcycle shop and use the CORRECT tool. It goes between the attached bearing and crank half and wedges between the two. Forcing pushing the bearing off the journal. It's very simple with the tool, and is the only correct way to do this. With warm cases and cold bearings, the new bearings will push into cases with you thumbs. Do not beat on them! And remember to install seals first on the Tecate engines.
  5. #50
    My local Auto Parts store had this tool in a set of 2 for 38$. Worth there weight in gold!! I'll post up a pic for ya.....
  6. #51
    NE Indiana
    1,067
    You guys are great with all the info. I appreciate it.
