Fork modification (pvc)
Well, I did the PVC pipe idea to try to stiffen my front end up on my 200x. I jump a lot, and needed a stiffer ride, so Im trying it out. Are you supposed to just put the pcv pipe on top of the top spring after you take the valve cap nut off? Thats what I did. At first I tried to put in a 1 inch long piece of tubing in each fork, but just could not get the springs comrpessed and start the nut on at the same time. x So I used 1/2 inch length for now. (still had trouble getting the caps on, they went on by a miracle) It works out pretty good tho! The forks are a little stiffer than before. I still want to take the 1/2 inch long pieses out, and put the 1 inch pieces in, so I was wondering if you guys had any good ideas on how to compress & tighten at the same time? Keep in mind I had the 200x on a atv jack with the forks off the ground the whole time. Are there any tricks to it? Thanx again. )
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
