Whats the best way to lube cables.
1984 Honda TRX200
1985 Yamaha 200ERN ( two of these now)
1985 Honda 250SX
1991 Suzuki LT230
2003 Honda Rancher 350ES
A Cabe Luber
lol, love saying cable luber!![]()
It is a small rubber clamp that has a hole for you to put the red hose attached to a can of WD-40.
http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
Heres how Ive done it for the throttle cable on my airboat: Take a long 8-12" piece of hose that you can slide over one end of the cable and then put a hose clamp around it and tighten, fill up rest of hose with what ever you have to lube with then insert the nozzle of an air compressor blow off attachment and put the air to it (helps to turn down psi on regulator to about 20-30 psi). do it till you see fluid come out other end.
