Results 16 to 30 of 43
Thread: interco vampire tire
    Mar 2005
    overton, PA
    5,257
    save your money and get the gators for the back also they are a much better tire and lighter to boot.
    Pensacola, Florida
    124
    I saw the mud bugs in 25 12 9 on ebay from a place yesterday for like 61.00 a tire on closeout. I'll see if i can find em here in a few.
    Pensacola, Florida
    124
    http://cgi.ebay.com/ebaymotors/MAXXI...Q5fAccessories
    Here are the mud bugs for 61.00 a tire
    Pensacola, Florida
    124
    I just checked GBC's site and the 25x12x9 is listed as having an outside diameter of 22.1" with only .75" tread depth. the mud bug will measure closer to 25 and the tread is .5" deeper, but the rubber is softer and they wear quicker, but they are also lighter so you won't lose as much hp. I have run both the gators and the bugs (gators with 1.25" depth not the .75" ones) they mud pretty close. however the mud bug in 25x12x9 vs a gator in 25x12x9 the bug will whoop it, its taller and has .5" deeper lugs.
    Apr 2008
    Manitoba Canada
    106
    Quote Originally Posted by acidburn View Post
    i guess im kinda screwed for tires :S gbc gators in my size and discontinued mud bugs are not in my size at the dealer around here....
    Don't get me wrong, Vampires are going to better than average, so you could do worse, but if I had a choice I'd have gotten something else. I ended up with Vamp because there was not much else available in my size, so you could do a lot worse.
    1985 Honda Big Red 250ES
    27x12-10 Mud Bug rear tires on ITP aluminum rims
    27x10-12 Mudlite on front
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    ok so ill probably go with those 61$ mudbugs from ebay has anyone ever ordered from that company on ebay??
    and also what tire should i go with for the front
    Pensacola, Florida
    124
    Don't get me wrong I dont work for maxxis and I am not trying to pimp their tires but in the 25x12x9 size you are limited. When I get another quad I'm getting gorilla silverbacks, thats a whole nother animal right there, wish they came in 25x12x9 or even 22x11x8.
    beaver bank, nova scotia
    72
    I would suggest that you run a mudlite for a front tire, they are directional, and have very nice side bite...
    2002 grand caravan (most uncool thing to drive but most practical)
    1993 trx 300fw-ol` blue
    1984 big red 200es
    1984 big red (swamp donkey 2)
    1984 big red daily driver
    1978 atc90
    1978 honda cx500
    1973 cb350four
    Oct 2007
    Grosse Tete, LA
    3,440
    look up tire weights... There isn't a trike out there stock that can correctly pull a 30 pound tire. Sorry, that's life.
    Your best bet is to hit rocky mountain for some xtl mudlites on some cheap rims... Even 27s weigh less than 22 inch vamps.
    Then again... You northern boys do have that mud that's more soupy than anything.
    Cornwall
    344
    how are mudzillas i found a pair in size 25x12-9 on ebay its either those or mud bugs
    Apr 2006
    PA
    1,464
    Mud bugs are not better than vamps unless your talking about the tsl. REGULAR vampires are alot heavier and have alot bigger lugs than tsls. I had a pair of 27x12x12 and 27x10x12s on a 4x4 and it was unstopable. They will climb anything you can throw at them. Anyway get the the TSLS, the regular vampire is just too much for any trike.
    Cornwall
    344
    Super Swamper TSL Vampire 25x13.00-9
    * Weight (lbs): 30
    * Ply Rating: 4
    * Tread Depth (Inches): 9.75
    * Tread Width (Inches): 25.2
    * Cross Section Width (Inches): 9x7
    * Diameter (Inches): 12.2
    * Suggested Wheel Size: 470
    * Max Inflation (PSI):
    * Max Load (lbs):
    seems the tsl is 30lbs also :S is this the ones your talking about and there only 4ply... thought they were 6.
    how well do tsl swamp lites perform the tread is almost as deep as vampires and weighs 23lbs
    Apr 2006
    PA
    1,464
    I guess they weigh the same, but the lugs on the regular vamp are 2x the size, just look at the pics on intercos website, big difference. I really dont see any trike turning the vamps in any kind of mud. The tsls would work but they are still heavy as hell. I think the lugs have alot to do with it too when you get in mud though, its 1'' vs 2'' open tread digging through. The tsls are 4 ply and the regular vamps are 6, but the tsls are the toughest 4 ply tire you could find.
    Cornwall
    344
    ok so im kinda confused in witch tire to get id like an aggressive tread for mud but a light tire so i keep my speed.
    so a few i noticed are
    ITP mud lite
    interco swamp lite
    anyone care to name some more??
  15. #30
    Oct 2007
    Grosse Tete, LA
    3,440
    Swmp lites on the rhino pull like hell, but they wear like
