Can ANYONE troubleshoot transmissions!
Well lucky me on occasion the 87 250SX goes from 5th gear to 4th!! or from 4th to nuetral until you shift up again. 5th and 4th are not pop wheelie SX gears or gears you really jam so I'm hesitant to say bad fork. Only happened a couple of times but I don't want to make it worse. Now if the cam stopper itself or stud were bad I believe that would affect all the gears not just 4th and 5th. If the drm advances and the gear dogs engage as I'm cruising along how can it possibly rotate the other way back to fourth?? Does that mean that 5th is only patially engaging and drops out due to a gear dog problem etc??? I would guess that the gear is binding on the shaft or the 3 holes in the gear that mate the raised nubs on the other gear are damaged. Yes, I know I have to take it apart but I did take the 85 with no 1st gear apart anfd that had all it's teeth so I'm a bit confused. Where is the TRANNYMAN!!!!!!
I have complete confidence in splitting this but I could really use some of your experience in the tranny areas of improper shifting.
