Results 1 to 15 of 19
Thread: trike will not start.
    Nov 2008
    ontario
    1,055
    i just got back from trying to start my 200s, i rode it last week put it in the barn and now today i took it out to ride it. i pulled it over 100 times choke on,off, half way, the spark plug wire is in, it has compression just like it did last week the gas is on and flowing, i took off the air box cover and it had a small amount of fuel on the tip of the breather tube, choke up gas would spit out this tube. please help me i was almost to the point of taking out the loader and crushing it!
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    well seeing how your from my area and it is quiet cold around here, how cold was it when trying to start your bike?
    mine will not start in -7+ conditions i have to take a small heater and let the engine warm up for a good 20minutes.
    Nov 2008
    ontario
    1,055
    yea its is warm today +8 where are you from i am in ingersoll
    Cornwall
    344
    did u try putting some gas on the spark plug? that usualy helps alot.
    using the choke has never helped for me, my bike is a 81' atc200
    Nov 2008
    ontario
    1,055
    what do you mean by on the spark plug you mean put some gas in the exspansion chamber? major problem was i have no tools out at my barn so it was hard to do anything but i found the right size socket
    Cornwall
    344
    just soak the tip that goes into the engine and tighten it back in it should fire up, also if your bike vibrates enough the screw on your carb may have turned back making it harder to start.
    Nov 2008
    ontario
    1,055
    i was actually messing with the screw last ride it wouldnt idle for long but come on after 50 pulls it should show some sighn?
    Cornwall
    344
    try the gas, if not it may be your screw there very sensitive SOB's
    Nov 2008
    ontario
    1,055
    alright i will try that i might take out the plug and burn the excess fuel in the combustion chamber with a lighter i remember my friend who used to won the trike did this once ater it sat for a week
    Lewiston, N.Y.
    1,477
    Your float might be stuck open allowing the excess gas to flow in and flood it out. Check the carb.
    Nov 2008
    ontario
    1,055
    how to i get the float unstuck? and would the fuel spitting out the air tube (no air filter) indicate a stuck float. i think i had the choke on when it was doing that
    Internet
    1,251
    Remove carb from bike and then remove the bowl cover. Have a look at your float and see if it moves freely.
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Clean the carb good, something is stuck or plugged.
    TF 07,08,09,10,11,12,13,14!
    Nov 2008
    ontario
    1,055
    could it possibly be really flooded? i mean it ran last week just fine
    Mar 2003
    3,092
    Quote Originally Posted by daniel_250r View Post
    Doubt it, replace the spark plug, and check your petcock, make sure it isnt plugged with rust and dirt, clean the fuel filter, and check the air filter.
