Results 1 to 11 of 11
Thread: questions on adjusting jets
    Nov 2008
    ontario
    1,055
    hi there i have a honda 200 carb here and am wanting to know what i am adjusting so next time i go out to my barn i can adjust my tri moto's carb. i assume they cant be too different... so what i am wondering is wich one is the main jet? howe do i adjust it? and please label what ever else you know [IMG]
    Nov 2008
    ontario
    1,055
    reason for all this is it idles, revs high and low but when in gear barely moves and bogs, so what do i need to adjust to change the air /fuel mixture?
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    clean the jet, not enough fuel passing through.
    or if that doesnt sound right, you have a air leak.
    Nov 2008
    ontario
    1,055
    so what jet am i cleaning? the big main jet there?
    Jan 2005
    RI
    2,530
    theres only 2, clean them both, and clean the rest of the carb while youre at it. all passages, etc...use compressed air afterwards too.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Nov 2006
    Seattle
    1,552
    Quote Originally Posted by DeePa View Post
    and bingo was his name o......
    Use carb cleaner, spray it all, then use thin wire on the jets and push through the holes, then spray again.
    Nov 2008
    ontario
    1,055
    ok, i have never done this before , so by two jets you mean the main one that as the screw driver head on it, and the brass one beside it, how do i get the 2nd one out theres no notch to get a screwdriver in there!?
    Jan 2005
    RI
    2,530
    if theres no hex head or screwdriver flat, its pressed it. just clean it out with carb cleaner and compressed air
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Nov 2008
    Coon Rapids, MN
    956
    Does the trimoto have the the stock carb on it. If it does first clean it then set the air screw by turning it in intil it stops then back it out 1 1/2 turns.Try that and see how that goes. Have you done a compression check on it and what did you get it. Should be at least a 100 psi. I will not be back intil nine tonight then if you got any more question I will try to answer them then.
    Alex
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Nov 2006
    Seattle
    1,552
    Quote Originally Posted by daniel_250r View Post
    are you sure? should be 2 flat head slots or a flat head and then a hex for a ratchet/wrench
    Nov 2008
    ontario
    1,055
    ok well i will try cleaning it tommorow and see if it helps, also the carb has a slide on it with a needle should i move this needle up or down with the clip would this have any effect? thanks for all the help guys, i would have alot of broken machines if it werent for you guys
