Just wanted to ask.
Just wanted to ask.
1985 Honda Atc 200M
Chain drive with no reverse, but has electric start!
I know I will forget a few things. But here is a quick list:
Air filter cleaning or replacing, Oil change, Valve lash, chain lube and tightening, tire air pressure, clutch adjustment, brake cable lube and adjustment, Throttle cable lube and adjustment, ect
Those are the things that should be done regularly to keep it running and rolling.
Howdy
Ok but how often are you supposed to change the oil and how can I find out how to adjust the clutch and chain etc? Is there a good manual I should get?
1985 Honda Atc 200M
i also own a 200m...i was wondering if theres anything i could do to help it perform better, with a budget of 50$ or under....i know its a long shot, but meh
1983 Honda 200e
1984 Honda 200es (needs rebuild)
1985 Honda 250es
1986 Honda 250es (parts bike)
1984 Honda 200es (parts bike)
Thats a good question. I was also going to ask the same thing!! Maybe we both will find the answer!Originally Posted by Psyonyde
1985 Honda Atc 200M
Check and replace your rear bearings often, especially if you are driving through lots of mud and water. I've had 2 200x's and an M that all had worn axles. Putting a grease zirk on the rear of the swingarm and keeping it full of grease isn't a bad idea.
The dead know only one thing, it is better to be alive.
200m's dun have swingers do they...............
matt
No there is no swingarm, nothing pivoting on the 200m. Bearing carrier would be more appropriate.
