What would make a Tecate just pour antifreeze out of the overflow as soon as the bike starts? The idle seems to be a little high as well.
I'm used to my 84 which runs top notch all of the time. The radiator and hoses are clear. The old radiator did have a lot of white crud in it. Last time I started it, it started with no leaking, until the trike was run for a while and it started overheating.
The cylinder head was leaking but not since the new head gasket was installed.
It is a KX250 cylinder, ported, with an intake spacer and a 41mm Mikuni falt slide carb. DG pipe and silencer.
How can you check the water pump without removing the cover? Can you look inside the radiator for signs in the fluids action?
Thanks in advance,
Doug
