Thread: atc 70 rear plastics almost hit tires
    pa
    137
    i just picked up an 83 atc 70 and the plastics are all but touching the factory size tires. is it possible for the rear seat attachment on the frame to be squashed from bigger guys riding? it doesnt look squashed. does anybody use any spacers in between the plastic and the frame?
    May 2007
    Coshocton, Ohio
    1,815
    I would guess that the fenders are sagging.
    Appalachian American Racing
    the home of
    May 2007
    Coshocton, Ohio
    1,815
    Quote Originally Posted by Daddio View Post
    Oh! to the forums
    the home of
    Bartlett TN
    3,083
    Well it does sound like the plastics are saggin. ALso check to see if the tires are over inflated. You could also check the mounting area on the frame to see if its bent at all.
    86-87 Tecate ROCK!
    BigRed_Ryno is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Kent UK
    311
    IF the tyres are the original OHTSU ones its probably that they are over inflated. The fenders would have to sag quite a long way to touch the tyres if they were the kenda scorpion replacements, as these dont grow in size with inflation, as where the original OHTSU ones do
    '85 ATC 200x-
    '84 ATC 200s-
    '82 ATC 70-
    '85 ATC 70-(project)
    '82 ATC 70-(project)
    Wife- (project)
