Thread: Big Red Reving Issue
    Conway, Arkansas
    Unhappy Big Red Reving Issue
    I've been toying with an 85' big red that has been sitting for over 2 years, i bought a new clarke tank, battery, spark plug, carb rebuild kit (which i have installed), and drained and replaced fluids. Before the carb rebuild but after all the other changes it would run real sluggish and die when given gas, now i runs like a dream except for the fact that it is over reving, it runs like the choke is on full all the time, having just rebuilt the carb im clueless. Any ideas?
    May 2008
    Juneau
    605
    check to see if the choke plunger is sticking
    3 wheelaholic
    ATC200/CR480 custom
    1984 atc250r near mint
    wr450f trike on the way
    Trizinger for my sons
    Feb 2007
    Nova Scotia
    18
    Yes I'd say the same thing check your choke, also check the idle adjustment. It might not be set right after the rebuild. Sometime carbs are tinkered with too much before the get rebuilt and if you record where all the adjustments are and put them back in the exact same place afterwards, Then they arn't set right for the clean good flowing carb.
    Just an idea
    Sep 2008
    845 New York
    2,302
    2nd what crashbang said bout idle adj.
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    check cable into carb
    I had a problem like that, turned out to be the threaded throttle cable seat had screwed out and needed to be turned back in. This is located at the top of the carb, were the cable enters the cap.
