Results 1 to 15 of 18
Thread: 1983 200X headlight
    OK
    5,450
    1983 200X headlight
    I just pulled off my headlight and removed the burned out bulb. Weird looking bulb. Where can I get another? Is there anything at O'reillys that will fit? Or is this a Honda only part?
    What kind of bulb is it, does it have an official designation?
    Thanks in advance,
    Doug
    Mar 2007
    Texas
    5,045
    ebay or www.bikebandit.com i beleive they also make a bulb upgrade for the 200x style light that is way brighter. I think sylvania has a silverstar bulb for it.
    ________________
    https://www.mikesatvfix.com
    OK
    5,450
    I see Bikebandit has it as a 12v/60w for the stock bulb from the oem parts. Is that an h4 bulb? With the wide base and the 3 prongs to fit the attachment point or bulb holder.
    Thanks,
    Doug
    Mar 2007
    Texas
    5,045
    you have to check the bulb on your bike and make sure it's matched up. not sure what your seeing, and i myself don't have a 200x "yet" but the 200x has the same bulb as the 350x and 250es/sx
    ________________
    bad350's Avatar
    bad350 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    kentucky
    176
    350x bulbs are different than the 200x
    Mar 2007
    Texas
    5,045
    ahh ok, i thought the manual said they were the same. ok my bad on that then.
    ________________
    Sep 2007
    100mi west of Chicago
    3,582
    Thanks,
    Doug
    I just tried this this morning with my wiring harness. A Philips H4 I had lying around from a car I used to have works. Its a 12v 55/60w.
    Rob
    Mar 2007
    Texas
    5,045
    ^ sweet! new trick! those are less than the atv labled lights.
    ________________
    Dec 2005
    Wisconsin
    1,141
    Quote Originally Posted by rdlsz24 View Post
    Rob
    Rob thanks for sharing this info. Now I can go to the parts store and buy a bulb.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    OK
    5,450
    Rob
    That's exactly what I was looking for, thank you, Rob.
    Doug
    Muskoka, Ontario
    12
    thanks so much. I've been looking for a bulb too.
    Sep 2007
    3,582
    The only thing is, it is VERY dim. Like it does nothing for you if you are riding in the dark. A flashlight taped to the handlebars would be better.
    Is the oem one brighter, maybe because a car bulb isn't getting enough juice? Or is the 200x light just dim in general?
    Rob
    Feb 2009
    michigan
    2,387
    no,it should be brighter than a flashlight.what bulb do you run in the tail light?the alternator puts out 60w at 5000 rpm's.check your connections.
    1985 ATC 250R
    . Team Red Trike
    Manitoba
    536
    I put a new stator in mine, and its bright even at idle. I used a standard halogen bulb from the auto parts store. They had ones that look just like what came out.
    84 200x
    Sep 2007
    3,582
    Was yours dim before the new stator? About how much did it run you?
    Rob
