Do you alwasy hear a pop? I'm battling a tire that wouldn't hold air for more than about 15 hours. I pumped it up to 50 psi, found a couple pin holes that I plugged, found a few spots on the lip of the rim that were leaking too. These rims got bashed a couple times pretty good.
So I let out all the air, used some spoons to pull the bead of the tire back from the rim (which was very easy to do). With the spoons and prybar I was able to straighten the lip out, clean it up a bit, etc....
I aired the tires back up to like 40 psi, check the lip and there were just a couple spots that were leaking. But when I stuck my tire spoon inbetween the lip and wheel I could "burp" some air past. Does that mean the bead wasn't ever seated to the lip? I tried airing up to about 60 psi and never heard a pop.
Anway, after sitting for a week, I rechecked the tire (which deflated, but this time it took a week to go down, which is a step in the right direction) and when i tossed 30 psi in there, air was leaking from all around the lip of the rim again.
I'm wondering if I just need to pull the valve stem and shoot a cool 100 psi in the damn thing so I can hear that "Pop" of the bead. Any advice is welcomed. I'm handy with bike tires/tubes, but new to atv tires.
