Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
Thread: 200X Burnt Valve or What?
    Grass Lake, Michigan
    54
    Question 200X Burnt Valve or What?
    So i Just put a Decompression Lever head on my 200x so i could use the electric starter, because the kick start spring broke. Well, all seemed well at first when it was cranking and then started. ran it for about 5-10 minutes, then, it stalled abruptly. Tried to electric start, no luck, tried to kick start, there was a lot of resistance when i kicked it. I jumped it after it cooled down a little, and it seemed OK till it fired, then it stall instantly and then it had the same HIGH resistance and didn't sound very good as it turned over. My thought is that maybe i didnt set the decompression lever to reset back far enough, and maybe it... burnt a valve?
    Please help..
    OH what to do???
    1985 200X (Stunt Bike)
    1983 250R (Beater)
    1985 Z50
    19?? Chopper Mini-Bike (4hp Intech)
    2001 Suzuki SV650 (Street Fighter)
    1999 Honda F4I (Stunt Bike)
    http://www.youtube.com/dizzost
    http://www.myspace.com/takemetodizzo
    Sep 2007
    oregon
    2,292
    come on at least let him know if he blew it up or not geez...
    Dec 2005
    Wisconsin
    1,141
    Sounds like something other than a burnt valve. When a valve is "burnt" it lets compression by when it's not supposed to, this would lead to very little to no compression when kicking. Sounds to me like you have a bearing problem somewhere.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Howdy's Avatar
    Celina, Ohio
    10,079
    Sounds like the top end might have gotten starved for oil and seized the cam. I have seen this a lot of times and almost every time silicon was used during installation.
    Howdy
    54
    seized cam, huh? Great. Well, that's better new then burnt valve. I've never burnt a valve before, so i didn't think i would lose compression, but that makes sense.
    What is still odd, is after it cooled for a minute it cranked fine, till it tried to fire, then stall, then it was tight again.
    Well, I'm gonna rip the valve cap of in a few, maybe howdy can check if he has a cam for me, just in case....
    I'll make sure NOT to use silicone putting the cap on when its ready.
    1983 250R (Beater)
    1985 Z50
    Actually burnt valves might be a better situation.....
    When the cam seizes, it ruins the aluminum journals and the whole head has to be replaced. Fortunately, you should be able to get another head pretty easy and reasonable here....
    PA
    3,515
    check your oil pump before throwing parts at it
    WWW.HREATV.COM
    54
    well, got her apart, valves are good, Cam bushing seized up but not completely. So it didnt spin in the journal. I noticed some minor marring on the sprocket side of the cam journal. DOnt know if that was there before this, and not sure if i should get a new, used head. I am poor, so most parts will be used. Oil is making its way to the top, but she may have just been ready to go, or i got some silicone in it.
    Lesson learned.
    Any one have a cam, bushing, and/or head for sale??? used and cheap please.
    Wink Wink, Howdy
    1983 250R (Beater)
    1985 Z50
    Apr 2006
    Crestview, Florida
    2,429
    I have a nice cam, busing, and head from a 85 200x. I might also have a nice 200e head if it isn't sold already, i'll have to check and see which head Allen wants. Make offer.
    Rides
    85 ATC350X
    85 ATC200X
    Mar 2007
    Texas
    5,045
    i'm jsut replace the head. you can get a good used 200s head off ebay for about $40 shipped. it will most likley be in running condition and you just drop and go.
    ________________
    https://www.mikesatvfix.com
    54
    Oooo, looky, Here's what I've found.
    Ebay Head
    Whatcha Think?
    1983 250R (Beater)
    1985 Z50
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Dizzo View Post
    Ebay Head
    Whatcha Think?
    Don't look bad, how ever I think you should be able to do better here on the forums ( saving money ). I need to check what I have available.
    Howdy
    Feb 2003
    Australia
    927
    Did you locate the end cam bush properly in the head before you put the rocker cover on? If the pin on the outside of the cam bush is not in the right spot in the head, the rocker cover will squash the bush onto the cam and cause it to sieze on the cam after a short while.
    54
    Should i post a WTB thread or wait to see if anyone reads this and offers something?
    I'l like the head to be complete (valves and all) I f anyone who asked me to make any offer can beat that ebay deal, let me know, please.
    1983 250R (Beater)
    1985 Z50
    54
    Quote Originally Posted by greenhuman View Post
    I didnt have the cam out. but, yes, yes the pin was in the detent, it was not damaged. i used silicone, like an idiot and i believe she starved for oil and seized. too many wheelies couldnt be the cause....
    1983 250R (Beater)
    1985 Z50
