A friend of mine has one here we're trying to work on and get going again. It won't start without putting fuel down the plug, and when it does, it idles, and it only idles. The throttle doesn't do squat. The slide operates and I've checked and done all the stuff. It runs very smoothly at this speed, but thats all it does. Switching it tothe run switch either kills the motor, or it increases speed slightly and the throttle still doesn't do anything. It seems to me like its being electronically governed to that speed or something in the ignition, is that a common problem or issue?
The second thing is getting it to start without dumping fuel in the cylinder...I read briefly during a search about the choke valve, if its not perfect it won't start, so thats probably what the issue is there.
But the governor thing...need to get that squared away first.
