Results 1 to 7 of 7
Thread: 1984 200x wheres the idle screw
    Oregon
    83
    ok i got that 200x and it runs just dosent stay running where is the idle screw and when i turn the gas on it come out of the over flow like crazy what do i do people?? btw i would be lost if it wasent for all you guys thanks again
    PA
    3,515
    the idle screw is on the side of the carb and it has a spring on it.
    the overflow problem is the float valve, take the carb off open it up and clean that thing till you can eat out of it.
    WWW.HREATV.COM
    Oregon
    83
    another question
    wheres the gas line from the gas tank go on the carb the copper fitting???
    Sep 2007
    100mi west of Chicago
    3,582
    Yeah it connects to that. Should be the only vertical inlet tube.
    Rob
    Oregon
    83
    ok on the pilot screw how do i adjust it??? how many turns
    Sep 2007
    3,582
    Pilot screw is on the bottom. Check out this attachment
    Rob
    Oklahoma
    62
    with it coming out of the overflow you should check the float and make sure it doesnt have a hole in it. If it does it will not float because gas gets into it and it doesnt float.
    81' Honda 250r
    84' Honda 200x...sold
    84' Honda 200s...sold
