Results 46 to 56 of 56
Thread: Project Atc 500r forward kick
  1. #46
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Love it...I've got to build one of those for my 500!
  2. #47
    Lookin good Jethro.
    Masshole
    2,191
    Well, didnt work out so well, the jackshaft ended up bending right where the splined end was welded on under the load of starting it.
    I think this will work great only if a decomp is used, its just too much piston to be throwing around with no comp release for my forward kick contraption.
  4. #49
    Jeff, is that just plain old cold rolled steel welded to those hardened splines?? I'm surprised it didn't snap.......
    We gotta find you a splined shaft made from tool steel. May need a center bearing being that it will be a shorter shaft (not sure if you even have the room to do that) but thats just me thinking aloud......
    You may even find a (correctly) splined longer countershaft or main shaft out of something.
    I bet those splines are the same as my 87 200X kickers but they'r too short to do anything with.
    Any idea how many splines there are and the OD??
  5. #50
    hey, you need to get it heat treated.
    one cylinder is not enough!!
  6. #51
    Moncton, NB
    106
    x2
    Heat it red hot and throw it in the dirtiest oil you can find (used diesel engine oil = better). The carbon and other impurities like nitrogen, phosphor in the oil is what you're after to case harden it. You could also throw it in urine or stick it through a body like they did with swords...
  7. #52
    Regardless, if he used cold rolled everyday steel, then it will never mate properly. You CANNOT heat treat 2 different steels the same way; I think he needs air hardening or oil hardening shaft material or a shaft from something that fits which is why I'd like to have the spline count and O.D.
    It seems his bent right at the weld or somewhere between the 2 bearings.
  8. #53
    osoyoos bc canada
    1,057
    Quote Originally Posted by BGP View Post
    x2
    this totaly works when i make gun parts i do this because i live in canada and hunt its a pain to find parts for any guns most stores dont sell small parts so we make them from normal steel keep them red hot for at least 5 min and dipp in used motor oil and repeat 3 times the oil you use cant have water in it or it wont work properly the water makes a steam barrier and the steel will be brittle the blacker the oil the more carbon the better it works
  9. #54
    Masshole
    2,191
    The stock is high carbon, not cold rolled. I think its because its welded right at the most vulnerable place, being so close to the bearing, and on the wrong side of the bearing.
    A one piece shaft would prob be much better, but im thinking its gonna fail somewhere else after.
    Theres just too much strain there, it needs a decomp, otherwise i will just be battling problem after problem.
    If i put a decomp on it, im sure if i straighten out the shaft i have, it will work fine.
  10. #55
    So did you ever get that jack shaft to work ?
  11. #56
    B S is offline New to the board Arm chair racerNew to the board
    Jul 2011
    CHICO,CA
    40
    i see it working if your able to use a pre made shaft then make a extension on the end of it with a set screw instead of wwelding it
    make sense?
    i could make a diagram ?
