Page 5 of 12 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 61 to 75 of 169
Thread: tecate pictures lets see what you got!!!
  1. #61
    Tekawte1's Avatar
    Tekawte1 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2007
    Indiana
    176
    Arrow
    Quote Originally Posted by hadar View Post
    Owe Yeah' Jeff. What kind of swinger do you have on that again?
    Well , in the pic its a stock swinger. Its a pic the day I picked it up. But the CALFAB I have is replacing that.
    Trikes make me drool TRIKEFEST 08 survivor And Sandpuppies 08 survivor
  2. #62
    Dec 2002
    Spruce Pine, Alabama
    1,263
    Quote Originally Posted by boosted96cobra View Post
    What front tire is on there? Stock sized rim?
    +1
    tecat-z,
    Is that a stock '85 wheel with the narrow Front Max on it like I did to an '85 in '07, or is that an narrower wheel?
    '84 ATC70.....my 8-y.o. son's ride
  3. #63
    Dec 2002
    1,263
    Here's my current Tecate. It looks so rough that I didn't really want to post a pic of it, but consider this a "before" pic since I've only had it since New Year's Eve. It's all original except Ricky Stator ignition, front sprocket, aftermarket air filter, and the rear tires.....even down to the piston(as story and inspection suggests).
    ALL that will change this Spring.
  4. #64
    Sep 2005
    MICHIGAN
    2,027
    Here's mine before this last summer's thrashing. It sports an 86 KX250 PC pipe with DG silencer turned upside down. A crappy 39mm Mikuni VM carb that I think has a float problem. A rear fender with a huge crack in it. A busted grab bar that was welded and broke again. LT250R 4/130 hubs. Cycra number plate.
    86 T3
    84 T3
    86 KX250
  5. #65
    2quicktecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    wa
    398
    nice trikes, can't wait to get mmy gasket...
    84 kxt250 tecate3
    87 kxf250 tecate4
    88 yfm100 yamaha champ
    85 200x high compression screamer
    Dam'n your bike must be fast! You were haulin ass when i passed you on my KAWASAKI
  6. #66
    Sep 2006
    Northwest Indiana
    1,893
    The swingarm is a +3 and very rare. It's my favorite part of the bike because of it's unique construction. Well..... that and the D.G. exhaust. Why does everyone sooooo under rate them for the Tecate.
  7. #67
    Quote Originally Posted by tecat-z View Post
    I put my DG on once while I was repairing my CRF (pipe) and the DG was awful.
    OK
    5,450
    I've used a Klemm Research sectional, DG, and the stock pipe on my 84. The Klemm Research was by far the best, DG was definitely better than stock. So in my opinion they are better than stock, and that was what they were made for.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
  9. #69
    Sep 2008
    Northwest Indiana
    550
    There it is....the DG exhausted Tecate that layed down the "Gauntlet" on everyone at Trikefest 2008. Doom is coming....
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
  10. #70
    Sep 2005
    MICHIGAN
    2,027
    I liked DG pipe on my 84 and the one on my 86 performed the same as the Pro Circuit pipe.
    86 T3
    84 T3
    86 KX250
  11. #71
    Apr 2008
    wa
    398
    i think i lost a bit of power when i switched from my old rusty bassani to a new dg. i'm having the bassanni restored and gonna use it with the dg type 2 silencer. the dg seems ok on my kx jugged motor, can wait to try the bassanni
    84 kxt250 tecate3
    87 kxf250 tecate4
  12. #72
    Feb 2006
    AZ
    1,358
    This is the rider i am finishing up. Its actually nice to not be so neurotic about the restore. Use what i have an not worry about oem obsolete parts.
    Its coming along nicely
    Just put the shroud sticks on last week.....
    '86 Tecate
    '85 ATC 250R
    '85 Tri-Z
    '87 ATC 200x
    '85 ATC 250R - Rider
    '86 Tecate - Rider
  13. #73
    NE Indiana
    1,067
    Well, I'm in the middle of restoring mine. I finally got it mached-up. It's my hybrid 1985 T-3. Do you guys think it's dumb of me to put the 86 parts on my 85? I just wanted to do something a little different. I have all 86 plastic. 86 front end and 86 swinger.
  14. #74
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    Hey 2quick, well that 250r may be mine... talked to the guy for about an hour;
    New engine and a spare that runs
    Original Tile/Certificate of Origin
    All new fenders, OEM and Maier and fiberglass rears?
    Detailed and cleaned every 2 years
    Setup for flat tracking and trail
    About 3 boxes of parts
    He wants 100.00 for it all O_O either the guy is jerking me around, or im in for a kick ass deal.
    BTW Hoosier, 86 front end looks good, better if the colors matched all around =P
    Nothing to ride... for now
  15. #75
    NE Indiana
    1,067
    Quote Originally Posted by Twilight View Post
    Thanks. The tank needs restored but the rest all matches. It's just the way tha camera flash worked in the basement, haha. I can't say it enough, thanks for your offer to help with the engine. edit
    Sounds like a killer deal on that R. Good luck, my friend.
