Results 1 to 2 of 2
Thread: how to test alternator ytm 200el
    canada,quebec,chertsey
    Question how to test alternator ytm 200el
    hello
    maby somone can help me with that
    im juste trying to know if my batterie is dead i can start the engine with the crank but the batterie do not charge so i want to test the alternator to know if its realy the batterie or the alternator ar dead
    did somone know how to test the alternator on a yamaha ytm 200el 1984
    tank you
    May 2008
    Northwestern Ontario, Canada
    552
    Pretty easy with any bike, but it sounds like it's the alt to me. Install the battery and check the voltage at the terminals. Then start the bike and check the voltage again. It should be higher, in the 14-15 volt range if I remember.
    Rev the engine, see if the voltage spikes, you might have a crappy regulator and that will burn out a battery pretty quick. Whatever you do, don't run it without a battery (even a crappy battery) installed or it will burn out.
    If I remember the alternator on my 200ek was just a coil that is accessed under the engine cover. Pretty easy to change, but watch the wires, they get really brittle with age, especially around the ends. Cheers.
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
