Thread: What carb is this???
    oOGoFastOo's Avatar
    oOGoFastOo is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Oregon
    265
    This carb is on my 86 Tecate and I can't find a idle adjuster on it? I have tried turning the choke knob and nothing works. It is a Mikuni and the only numbers i can find on it are T38 01 on one part and T5 Y1 on another part. Also I installed a thumb throttle off of a KFX 400 and it doesn't open the slide all the way unless i tighten up the cable so much that the slide wont close all the way; and on the top where the cable goes in there is a extra hole in it that is siliconed up. It seems to run good but just wont idle, any input is greatly appreciated. Thanks
    Attached Thumbnails Attached Thumbnails carb1.jpg   carb2.jpg   carb3.jpg   carb4.jpg
    2quicktecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    wa
    398
    4 stroke thumb throttles are different. i tried to mount one on my 84 tecate. ended up loving the stock twist throttle. you need a kxf throttle
    84 kxt250 tecate3
    87 kxf250 tecate4
    88 yfm100 yamaha champ
    85 200x high compression screamer
    Dam'n your bike must be fast! You were haulin ass when i passed you on my KAWASAKI
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    I think those style carbs were used on LT250R Q-Racers mostly. If memory serves me correctly, there should be (or had) an adjuster that threaded into the top cap of the carb, (kinda like the adjuster on the clutch lever). What you would do is turn it counter clockwise, which raised where the cable seated into the carb, thus lifting the slides resting location giving you your desired idle. I just used an adjuster off of the handbrake for a bicycle, fit perfect. Or maybe you could use washers, or a small nut to raise the seat on the carbs mounting plate.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Fresno Ca
    2,695
    That is a Mikuni Flat slide carb,
    Some people love those.
