now its bogging, have to gradually give it gas, where before you could punch and it would revvvvvvv. Any ideas???
I did not touch any of the settings it came with.
1984 200ES first Shaft driven big red with reverse!
85 Big Red 250ES with a rebuilt top end!
Whats the make and model of the ATC? You might have to adjust the air screw.
was the new carb a replacement for your bike or an upgrade?
OEM style for my 84 200es
so its the same thing you had?
if so open it up and see if it has the same jets/needle as the first one.
WWW.HREATV.COM
I really didnt want to take it apart. The A/F screw, opening it does what. closes does what????
taking the bowl off is 3 screws. it's very simple and yes you have to ensure you are running the same size jets. w/o knowing you'll never get it dialed in.
________________
https://www.mikesatvfix.com
its not that im lazy, worried about damagine gasket on a brand new carb.
Your gonna have to pull the carb, just be carefull not to rip the gasket/o-ring. Check the jets make sure there the right size and the needle is in the middle position, I think thats stock setting for that, not sure on stock jet sized tho.....98 mabey for the main??
TF 07,08,09,10,11,12,13,14!
tap it with the handle of a screw driver, if not, let it sit in a bowl of gas..
Rebel this is a very helpful info guide to carbs. It's worded so anyone can understand it.
http://s.com/performance/basictuning.html
It's a celebration bitches!!!
