Results 1 to 11 of 11
Thread: Big Red shifting problem
    Feb 2008
    Pennsylvania
    2,305
    On one of my big reds the shifter doesnt pop back when shifting(especially down shifting). How hard is it to replace the shifter spring? It doesnt look to hard in the manual, but I have never replaced on before. Where would I beable to get one? Does Honda still make this part? Any idea on a part number?
    '86 Honda Big Red 250es
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    '00 Honda Trx 90 (sons ride)
    atc70/110
    Eastern Long Island
    1,688
    The pin probably broke or the shifter shaft itself may be bad. Easily fixed with just removing the outer covers. I may have any parts you may need as well as the manual. Shoot me a PM if you need anything.
    Lots O Trikes!!!!!
    Michigan
    1,144
    I had a 85 sx that had the same problem. There is a little pin inside the cover that was broke. I got a new one from my Honda dealer. I can get a part # tomorrow if you need it.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Feb 2008
    Pennsylvania
    2,305
    Hublake, if you could send me a part number that would be great. 200xman I will let you know if I need any parts.
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    atc70/110
    Mar 2008
    Wichita, kansas
    123
    same thing happened to my big red i took the case off used a bolt in place of the broken pin worked fine and dident have to wait for parts
    My Rides
    1985 350x- Super Trapp Exhaust
    1984 YTM 200
    2005 Trx 450r
    Eastern Long Island
    1,688
    Quote Originally Posted by codemanlyons View Post
    I really don't see how that would work? Did you use a really long bolt and just bottom it out in the threads?
    Lots O Trikes!!!!!
    Mar 2008
    Wichita, kansas
    123
    i used a bolt and some thread locker to keep it in place and used a nut on the other end
    My Rides
    1984 YTM 200
    2005 Trx 450r
    Howdy's Avatar
    Celina, Ohio
    10,079
    If Todd don't have the parts, I know I do. I have everything but the left side cover gasket ( might even have that too.
    99% of the time the left side cover is the only cover you neeed to remove to fix this problem.
    Todd, I have made a quick pin before to get a friend back riding. I could show you one. :lol
    Howdy
    Michigan
    1,144
    Shifting Problem?
    Here is a picture and part # of the part that I replaced. In the picture the number is 21 located in the upper right. The part number is 24652-HAO-000 That is a honda number right from my parts manual. Hope this is what you need. As I mentioned earlier I got this part from my Honda dealer
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Feb 2008
    Pennsylvania
    2,305
    How much did that part cost? Did they have it in stock?
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    atc70/110
    Howdy's Avatar
    Celina, Ohio
    10,079
    they are only a couple bucks ( the time I bought a new one ), how ever they had to order it.
    Howdy
