Results 1 to 14 of 14
Thread: 200x questions
    Mar 2007
    Texas
    5,045
    200x questions
    84 200x, (not confirmed it's an 84. here's the vin, can some one check?)
    JH3TB0525EC323101
    will the Swingarm Pivot Bolt from a 1985 Honda 200X fit the one I have?
    Whom makes swing arm rebuild kits?
    I am going to need the following immedeatly.
    • on/off switch assembly
    • front brake lever setup (master resivore is trashed and i beleive the cyclinder is probelby shot (unless there's a rebuild kit for it)
    • new clutch and any other cable
    • new brake pads
    • new plug
    • new rear bearings
    • new swing arm bearing setup
    • rebuild carb
    • new fuel pecock
    ________________
    https://www.mikesatvfix.com
    PA
    3,515
    all 83-85 parts interchange
    WWW.HREATV.COM
    Mar 2007
    Texas
    5,045
    SWEET!!!! TY sir!
    ________________
    Mar 2007
    Texas
    5,045
    where can I get a rear shock rebuild kit?
    ________________
    Feb 2008
    Berlin,CT
    61
    if you find one can you pm me with details?
    85 200x-redone frame up,extened rear axel,clarke plastic gas tank,dg exaust system,ceet atc seat cover,and much more....
    86 klt 110 - stock in need of top end rebuild
    PA
    3,515
    no kits that i know of but i have a site saved on my ps3 that sells TONS of factory shock parts.
    no part numbers though since i guess they are straight from showa and not honda, but they have the measurments so all you need to do is measure you seals and bushings and your set.
    i'll get it for you later.
    WWW.HREATV.COM
    PA
    3,515
    WWW.HREATV.COM
    Mar 2007
    Texas
    5,045
    sweet thanks!
    I'll cotnact them and get details on what they need. then I'm gogin to tear my shock down and get a listing of parts. once I have that listing and can get a matching setup from them, I'll work onseeing if they can be offered as kits.
    ________________
    Feb 2008
    Berlin,CT
    61
    ok sounds sweet cant wait thanks!!
    Internet
    1,251
    I also have a quick 200x question - anyone make a rear sprocket bigger then 40 teeth to fit 83-85?
    Mar 2007
    Texas
    5,045
    hrmm not sure. if I find one, I'll let ya know.
    ________________
    Feb 2008
    Berlin,CT
    61
    i have in seen any thing bigger than a 40 i dont think so
    Internet
    1,251
    I ordered a 40 tooth anyways - gunna offset it with a 12 tooth front.
    I should be at a 3.33 gear ratio.
    BigRed_Ryno is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Kent UK
    311
    Quote Originally Posted by Saul View Post
    Why not just go a tooth (or two) smaller at the front?
    '85 ATC 200x-
    '84 ATC 200s-
    '82 ATC 70-
    '85 ATC 70-(project)
    '82 ATC 70-(project)
    Wife- (project)
