Jetting Advice 28MM FS Mikuni, 200X race motor - DUMB AGAIN!!
My god, everything I have read, everything I "thought" I understood is making no sense to me.
Telling you what I have for mods means nothing, it's all about how it runs and what it's telling you.....
I am running great on top, 3/4 to WOT so I'm very close on the main which of course has a trickle down effect.
So here is where I AM COMPLETELY LOST!!
I am running a 28 Mikuni that had a 20 pilot to start.
I am up to a 50 Pilot now.
The choke is nearly useless which says RICH and I'm watching my front half of my Suertrapp pipe turn cherry red
YOU TELL ME!! that means lean!! but the choke being useless means rich!! and those are all 0-1/4 throttle of the circuit!
There are no air leaks, no worn carb, no float problems and I have the conflicting issues......
Does it make any sense to PEOPLE THAT HAVE TUNED AND BUILT MOTORS?? Because it does not make sense to me...
If your choke does nothing, your too rich on the pilot. If your pipe glows red at idle you are too lean!! WTF is going on here??
I would up my pilot to a 55 (from50) which is the LARGEST one they offered at a given site, but then I wouldn't even have to choke it at that point which is wrong in 15 degree weather. It seems to be COMPLETELY asssbackwards??
The ONLY variable is the "air jet" which of course I can't find one piece of literature to say " the air jet is responsible for..............................BLAH BLAH BLAH!!!
I "THINK" it allows more air into the choke circuit when the choke is on. So, if I drop it down the choke may work again. BUT! even then, why at idle with a 50 pilot. 1 turn out is my pipe turning red - LEAN LEAN LEAN!! A 50 pilot jet in a MIKUNI IS LEAN!!!!!!!!!!!!!!!!!!!!?????????????????????????? ??????????????????? NO AIR LEAKS!!!!
I'm so pissed off that I can fix anything mechanical yet this thing makes me feel like a complete IDIOT/NEWBIE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Air jet?? Anyone?? Please!!
I'm not satisfied with "good enough" I want to get this close to dead nuts!!
