Results 1 to 2 of 2
Thread: Jetting Main question K&N
    Nov 2008
    Hammond, Louisiana
    33
    Im intrested in putting a new K&N Filter on my 200x. Im running a 110 Main stock and my Question is should I jet up when I do put the new K&N on and howmuch? also isnt the mains from 110, 112, 115 increments?
    Mar 2007
    Texas
    5,045
    i don;t think you will haev to rejet, I would adjsut the bottom screw about 1/2-1turn out then change the clip on the needle to be 1 down from the spot it is now.
    see if that works before you go jetting. if you do jet, then a 112 should probebly be the largest u would need. it's just a air filter in the stock box correct?
    ________________
    https://www.mikesatvfix.com
