http://cgi.ebay.com/ebaymotors/honda...Q5fAccessories
I know I'd buy it!!
Bid away boyz..............
I know I'd buy it!!
So whats the deal with this cam is it really big and nasty. I want to change the cam in the wifes auto X so is this to much cam without doing lots of other changes along with it?
Master of the DX and Pennsyltucky survivor ,08,09. Thats something to brag about
you would have to call up TC and ask what a #34 200x cam is.
i forget the number on my 350x TC cam but its a high rev cam and i dont realy like it, but dont forget with any bigger cam you need HD springs as well.
WWW.HREATV.COM
If you start putting big cams in an auto x, you could start having shifting problems. Those auto shift set ups weren't made to take lots of power. Also since the cam has a bearing on the end, unless your head had been modded to fit a bearing, that cam won't work. You would really need the whole head and cam assembly. The seller doesn't realize the cam and the head to be sold as a set. The head is probably ported and flowed to run that cam too. The seller just doesn't have a clue.
WWW.HREATV.COM
I thought it was a stock bearing also??
Anyhow, of course you'll need springs and a HC piston - BLAH BLAH BLAH........
But, cams aren't cheap and it might be a cheap buy for some1 that was looking......
Oh Ok then I will keep lookin and learnin.
If that's a stock bearing than that would be lots better. I don't know the bearings just by looking at them. Thanks for pointing that out. It could very well be a deal then if the cam isn't too radical.
Id like to see this carb and Sparks pipe...
1985 250R Selveys port job and pipe
1985 70 piped for lil'freaks
2001 TRX90
ATC 90+250R+BEER= Drag Bike
1984 ATC70 Pit bike
1984 110 for sale
