Results 1 to 9 of 9
Thread: Advanceable flywheel on ATC70?
    Nov 2004
    Waterloo IL
    2,701
    Has anyone or is it possible to put a flywheel from a Hand clutch model Honda 70 on a ATC70? I wonder if it would be worth it? I have two 4-speed hand clutch Trail 70s and an SL70 that is also 4-speed and hand clutch. These models have a flywheel with weights on the inside that fly out and advance the timing kinda like in an old distributor for a car. Obviously that will make more power but I wonder how much? I was looking at one of the flywheels and there is no place for the recoil starter cage to bolt on. That could probably be overcome. But someone told me that one year Honda chanaged the taper on the crankshaft where the flywheel bolts on, so older flywheels and newer flywheels will not interchange. Anyone else heard that? Thoughts?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    wow its about time someone else asked this question... i wondered this 10 years ago,,, i never tried it,, because the 70 only makes 3.3 hp ,,, so i never figured it was worth it,,,, but now i think maybe you should do it and report back ,, maybe it would be just enough to actually make a difference in the topend.. i was always looking bigger,,,
    Dec 2007
    Quebec,Canada
    1,014
    My sl70 have the flywheel with weight,and it's not the same crankshaft as a ct70 with auto clutch.if this can help....
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    May 2007
    Coshocton, Ohio
    1,815
    It would surely require machining to the flywheel so that the pull start could be used. I have an sl70 engine that I bought for the manual clutch set up to use on a ct70 but it was missing the flywheel. I'm not sure how much of an increase this would make in hp on something with 3.3 hp. How about the cdi conversion for the 70? That seems like it would be easier. I'm building a 70 now and I've been kicking all of these ideas around also.
    Appalachian American Racing
    the home of
    Baltimore, MD
    6,088
    Instead of trying to machine everything to fit the atc70 engine, why don't you just swap engines? It would seem much simpler. I have an suspension 70 with the xl70 sitting in it right now. It's a bolt on switch.
    May 2007
    Coshocton, Ohio
    1,815
    Isn't that a kick start engine?
    the home of
    Baltimore, MD
    6,088
    Yep, kick start engine.
    Feb 2003
    Australia
    927
    You can do it but only certain models. The taper didn't change, just the crankshaft length.
    The 70 models with the fat pull starts( steel flywheels) the SL/XL advancer flywheels fit right up. If you want to put one on the earlier models, you will have to fit the SL/XL 70 crankshaft and make a spacer for the thinner pull starts.
    Theres a little bit of work fitting the pull start ring but its doable.
    This mod certainly makes a big difference to revs and top end power.
    BigRed_Ryno is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Kent UK
    311
    So apart from originally being from different bikes, whats the difference in these two? (apart from the price)
    http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=018
    They've both got advancers in them, do they both acheive the same thing?
    'coz apparently most C70's came equiped with the second one?? my atc70 doesn't have it.
    '85 ATC 200x-
    '84 ATC 200s-
    '82 ATC 70-
    '85 ATC 70-(project)
    '82 ATC 70-(project)
    Wife- (project)
