Results 1 to 15 of 23
Thread: Bent Forks 250r. Question.
    Mar 2003
    Australia
    1,919
    Hey guys. Pulled my front end apart today and found the worst. Both for tubes are bent at the bottom tripple tree clamp. Looks like the hit was even because they are bent exactly the same amount. Tripples and axel is fine. Bars are also bent. My questions are..
    Will it be alright if I make sure the bends rake forward, and make the bend face the exact same way on both legs so it tracks straight?
    Also, the inner bushes in the forks (copper coated bits) area bit worn. In the manual it says to replace them if they have a bit of copper showing through. They do. Should I replace them, the front did not have any slop beforehand..
    While also on the topic, nobody has a set of good for fork tubes for a 250r do they? I would rather replace but I have a feeling its going to cost me.
    Thanks Guys.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Jun 2006
    Illinois
    491
    IMO, You should replace the forks if they're bent. Forks are available, either on ebay or from somebody on the forums. And whatever you do, don't jump it!
    It will probably cost you some money, but what is your safety worth.
    Jun 2003
    englishtown NJ
    2,676
    why don't jump it?? I did mx for 6 years on trikes and the only time I bent forks was during a crash. I jump my forks alot.
    Mar 2007
    Texas
    5,045
    bent forks can crack at the bend spot and break.
    ________________
    https://www.mikesatvfix.com
    Tionesta, PA
    5,747
    a machine shop may be able to straighten those for legs. You would need to disassemble them most likely - but it is a cheaper option.
    Nov 2008
    ontario
    1,055
    i wouldnt run bent forks they are over 20 years old, they will be weaker after you straighten them, they could snap any moment while riding them and that won't be fun. Check you frame for bends and your steering bearings for damage
    proud owner of a trx300ex quad and an 85 atc 70
    You guys are talking about forks that are almost never bent further than .125 - and thats the extreme. Most, I find to be bent under .030 and I have fixed dozens in my hydraulic press. Forks are not thin, they have a thick wall or they would crush as I bent them back the other way.
    I would not hesitate to run and jump with forks that have been bent and fixed. Unless of course they were bent immensely and at that point, thy usually cannot be fixed.
    And much to many peoples surprise there are a ton of mildly bent forks out there that the owner is unaware of.
    Nov 2008
    ontario
    1,055
    yes you are right really depends on how bad they are.
    Jun 2003
    englishtown NJ
    2,676
    I had the option of re-bending the forks I bent straight, the guy said that most likely they'd be fine. I didn't want to take a chance. The last thing I wanted is to come down from a jump and hear a "snap" and the fork tube breaks on me.
    Mar 2005
    overton, PA
    5,257
    any good machine shop can press them back true i have done many of them. a slng as they arent kinked they should be fine. i have bent my old 200x forks back any times and it took gettign backed over by a backhoe to finaly break them.
    Mar 2005
    overton, PA
    5,257
    another thing is the only time there woudl be prssure to bent or break them is when hard braking or hitting comething when jumping them the rake compensates for the forward motion and provides smothe travel. and have you guys ever cut a set of forks how thick they are? i am gonna do an experiment now that i am on the subject see how much pressure it actualy takes to bend or severly break a fork lol check back shortly and i will let you know my resaults!!
    Mar 2007
    Texas
    5,045
    remember uysing a press to bedn then is not the same as a sudden impact force. it may take 2 tons to break in a smow moving press but only 500lb of shearing force. shearing force is different than bend and snap force. it;s the sheering force that would concern me. how stabel is it now that it's been modified would i wonder. if i was jsut trail riding, then no biggie fix and go, but he's MX and to me that means safety first over a $100 set of forks.
    ________________
    Aside from the backhoe story.
    Have ANY of you ever seen a set of snapped forks? EVER?
    I've seen a frame neck break off, I've seen a tripple clamp step snap but never a fork tube. I'd be more concerned with the aluminum rather than the chrome moly tubes.....
    Mar 2005
    overton, PA
    5,257
    here is the results of my experiment. i locked a old previously bent 200x fork into the pin hole on my excavator thumb and curled the boom liek i woudl if i were digging against a large tree, the kubota makes 3000+lbs of break out force so figure the excavator also weights 7800 lbs. i pulled the excavator with the fork tube againast a rather large tree. so yeah they will kink and bend but they wont break and after the pic was taken i tried to break it and i couldnt so you tellme if i am wrong for trustign a straightened fork. and if your talkign abotu shear force the pin how it was mounted was the same way a tripple clamp woudl hold the fork so u tellme?????? i woudl immagine the tripples of frame woudl brake befor the forks wood.some people just dont use comon sence.
    racerxxx's Avatar
    racerxxx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Pennsylvania
    383
    Let me throw some gas onto the fork fire---what about inverted forks???? the smaller part of the tube is the bottom leg and the aluminum is mounted to the tripples. Wouldn't you think as the lower tube is compressing up into the fork and force back on the front tire-- imagine the force at the seal area. those xgames dudes are probably running killer forks, but nothing like NASA would build.
    My vote take em' to a mach shop have them tweak them in a hydraulic press, rebuild them.
    DC didn't you do a post of straightening a fork before (someone did)??
    My old man straightend my old tecate axel in his machine shop before---straight a pin!
    hold on let me get some matches
    What ever you do, do what YOU think is safest.
    Racerxxx
    1985 Honda 125M (My first Trike--Still have it)
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    1986 Yamaha YFM80 (Sons quad)
    Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
    1987 CR-80, 70's vintage XR75, RM 370
