Results 1 to 11 of 11
Thread: 84 250R Exhaust?---por-15 question too!
    Ontario
    46
    What kind of exhaust is this? the guy who is selling it says it might be a DG or a bessani....i really really hope its a bessani because i hear they are damn good and it doesnt look like a DG. THANKS! Also, i just coated the inside of my tank with POR-15 tank sealant and its been drying for about 4 hours. its starting to feel pretty dry but the can says to wait 96 hours for it to be complete. does it really need to dry for that long or can i just start using it in a day or so? is it a good idea to use 2 coats, if so then how long do you wait between coatings?
    Ontario
    46
    anyone have any idea?
    Apr 2007
    It's a cobra pipe and silencer.
    Airfoolers RULE!!!
    Ontario
    46
    are cobras any good? ive heard mixed stories about the 4 stroke pipes but ive havent heard aynthing about them for a 250r.
    May 2007
    Coshocton, Ohio
    1,815
    1upfront seems to have good luck with this one. A lot depends on how the machine is set up and most importantly how well it is tuned. It is pretty much the same as a dg pipe.
    Appalachian American Racing
    the home of
    Ontario
    46
    ok i think ill pick it up if i can then! thanks
    MA
    385
    BTW, it's bAssani.
    sbjones73's Avatar
    sbjones73 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    wisconsin
    414
    i would like to see the other side of the pipe.
    as far as the tank, let it sit as much as possible. it needs to cure.
    84 250r gone,
    87 suzuki lt250r trail machine, gone to fund ice racer,
    85 250r ice racing project started !!!!!!
    Mar 2008
    EastGreenbush, newyork
    3,494
    I would definatly let the tank sit for the recomended time
    Dec 2002
    deer park, texas
    2,336
    The por15 tank sealer needs to set 3 - 4 days at above 70 degree temps. Longer if below 70. It usaully appears dry within 24 hours but dont let it mislead you. If it doesnt cure completly before you put fuel in it, it will start to pull up in a few months. Also do not put on two coats. It seems this stuff has a problem adhearing to itself and you might get it to thick where it will not flex with the tank and start cracking. If you follow the directions exactly this stuff cannot be beat, it will last forever.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Aug 2005
    HI
    1,575
    Quote Originally Posted by aaron7 View Post
    BTW, it's bAssani.
    fail. The welds are all wrong and in the wrong places for it to be a bassani
    Rest in peace Rex Carlson
