Results 31 to 45 of 58
Thread: need HELP! tecate head gasket... pics of 2nd bad gasket and mating surfaces
  1. #31
    OK
    5,450
    How about your Bassani and cash on my end for the cylinder?
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
  2. #32
    2quicktecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    wa
    398
    sure that cyl. and 30 cash to cover shipping on my end let me know...
    84 kxt250 tecate3
    87 kxf250 tecate4
    88 yfm100 yamaha champ
    85 200x high compression screamer
    Dam'n your bike must be fast! You were haulin ass when i passed you on my KAWASAKI
  3. #33
    Apr 2008
    wa
    398
    think i may have just sold the pipe... please im me what you want for the cyl...
    84 kxt250 tecate3
    87 kxf250 tecate4
  4. #34
    Mar 2005
    ma
    988
    the sleeve looks like it was installed wrong. its to low. it should be even with the top of the cylinder. do the ports line up?
    you would need to have the studs removed and have the cylinder decked to be even with the sleeve. then the head should be cut , recesed so the piston doesn't hit. but also keeping the compression and dome angle correct.
    putting a thicker or more base gaskets will change your port timing.
    might just be easier to have another sleeve installed correctly! or get another cylinder.
    when the cylinder is tightened down, does the sleeve move up, to be even with the top of the cylinder? i had an rm like that, where the sleeve would move!
    i only readthe first page!! so i think this has been covered already!! lol
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
  5. #35
    Apr 2008
    wa
    398
    the sleeve dont move, the port line up well, and if it's low the port timing would be off, so the spaced base gasket would probably correct it.. i don't know hopefully i get this other cyl.
    84 kxt250 tecate3
    87 kxf250 tecate4
  6. #36
    Hey 2quick, you're not stil looking for a stock flywheel are ya? I've still got one that is on one of my motors and I picked up another bottom end this weekend with a flywheel on it. Haven't yet pulled either one of them so I don't know the condition of either one...
    Apr 2008
    wa
    398
    i already got a ricky on my trike
    84 kxt250 tecate3
    87 kxf250 tecate4
  8. #38
    Oct 2005
    saratoga, ny
    2,819
    why do the coolant holes look so small on the gasket as opposed to the coolant ports on both the head and cylinder? maybe ristricting flow and causing enough pressure to make it leak? dont know, maybe im just tired and seeing things.
  9. #39
    Dec 2002
    Spruce Pine, Alabama
    1,263
    Wow, some food for head gasket thought in this thread. I guess I've just been lucky up til this point in having whatever I used work. Come to think of it, I've never used a torque wrench on a wheeler or bike topend....so I've been real lucky.
    2quick,
    I'd be interested in the troublesome KX cylinder if you snag the other one. Just let me know.
    '84 ATC70.....my 8-y.o. son's ride
  10. #40
    My god what a shitshow this has turned into.....
    Use some silicone and tighten it with a 1/2 breaker bar about 2 feet long - problem solved
    WTF good is OEM or Vesrah or Cometic if the i9s all on a different surface??
  11. #41
    Apr 2008
    wa
    398
    the coolant holes are suppose to be like that. it's not getting hot a boiling the water, it was getting compression/combustion pressure in the coolant cause the overflow to spew constantly, i think i have it this time. you could totally see it leaking through the 10 grit scratches that the machine shop charged me to do, i know i wont go there again...
    84 kxt250 tecate3
    87 kxf250 tecate4
  12. #42
    I said there were other issues...
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    Try a oem gasket or another aftermarket with some copper spray, torque down nice and tight and try it.
    My pilot and 350 odyssey needed extra torque... just used hands and went in criss cross pattern
    Nothing to ride... for now
  14. #44
    Apr 2008
    wa
    398
    should i use the copper spray on the oem gasket? where do i get the copper spray?
    84 kxt250 tecate3
    87 kxf250 tecate4
  15. #45
    Sep 2005
    MICHIGAN
    2,027
    Permatex copper spray a gasket. I use it and buy it local auto store Autozone.
    I use a short box end wrenches to over tighten things so I don't have too much leverage.
    86 T3
    84 T3
    86 KX250
