does anyone have a bored 350x?
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
Im thinking about getting the 393 kit.
http://www.powroll.com/honda_atc_350x.htm
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
What do you mean by bored? Big bore or just standard bore jobs?Originally Posted by Honda atc70
big bore
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
what do you want to know about them? what size? 360-500 how to do it? bore and stroke. the big question is what type of riding do you primarally do. then there is how much can you spend. how reliable do you want? the bigger you go the less reliable. how about compression do you want to run regular pump gas or can you go through the hassle of race gas. then there are all the "extra" parts needed to complete the so called "kit" i personally build a 400 kit of which all of it but the 6mm stroker crank is listed on ebay as a 360 (the 6mm crank makes it a 392cc). very similar to powrolls 393 kit but my kit is a higher reving version and i use a better (billet) cam vs. there (reweld) cam
im not to sure though its either that or ill get a uni filter jet kit and cobra pipe.
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
well how much does your budget allow. most big bore's are arond 1,500.00-2,000.00.
im 90% sure ill get the filter jets, and pipe instead.
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
