does anyone know what all is a direct bolt on top end. xr 500, nx 650 or what. im trying to go bigger since im tearing the motor down
1-86 350x runs decent- stolen
1-85 350x rough but runs strong 80mph per gps
1-85 350x completely restoring-frame blasted and painted
2-85 350x frames with engines messed up
1-85 atc 70 runs been in storage most of its life
I don't believe that there is a direct bolt on without alot of work. Check out SWIGIN's thread on the ascot 500 head swap.
the only bolt on is the old trx foreman 350 top ends....but they are the same so no gain.
WWW.HREATV.COM
i thought at least the XR350 would bolt on...
My man Joe Dierte said it best... "I'm new, I dont know what to do!!"![]()
couple of 350x's, couple of blasters, couple of TRX 250r's, a zilla, and 92 hybrid LT250r / 87 LT500R motor...lets ride!!
well i read somewhere that a 500 would bolt on but i think they are 2 carbs but maybe you could use the head off the 350. not sure
www.theoldone.com
CNC porting and CNC valve seat cutting and valve jobs.
________________
https://www.mikesatvfix.com
WWW.HREATV.COM
but if you bolted on the XR500 cylinder, then the head would bolt on, yes??![]()
+1..... valve job!!!!
80' Honda CR80R
78' Honda XR75
77' Honda CT-70
74' Honda CT-70
75' Yamaha GT80 Enduro
76' Kawasaki KZ900
73' Kawasaki H1-500
76' Kawasaki H1-500
WWW.HREATV.COM
don't ya just love when those smart ass comments bite ya in the ass.
I'm thinking that xr500 sleeve is looking better and better every day swigin. with stock valves, high lift cam, and porting...will it be alright? or will it not flow enough?
need a 3mm spacer plate or a shorter crank...right?
couldn't you just have your piston cut down 3mm? and take 3mm off the bottom of the sleeve? or no...
the 500 sleeve is by far the way to go and my buddy who does my porting runs a 500 sleeved and stroked 350x with a fully ported 350x head and a megacycle xr500 cam......it KILLS built 450s.
he is the one i talked about in my ascot head swap thread.
shorter rod not crank....spacer would work too if the timing chain is long enough
WWW.HREATV.COM
so then why the ascot head instead of a worked over 350x head?
with a spacer and some rework can the xr500 cylinder be modded to bolt on? or how about just swapping the whole motor for a xr500 or 650?
i guess you didnt see my ascot thread....i show how much larger the valves are and i just wanted to see if i could do it.
you would have to gat a xr500 cly and see for your self why it nots worth the effort.....why mor work then a simple sleeve swap in a 350x jug.
as for your last question, why do guys built up 90s and 110s?......because they can. anyone can throw a bigger motor in a chassis. besides, my custom RX chassis is built for a 350x motor and im NOT hacking it up.
WWW.HREATV.COM
