Page 5 of 14 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 61 to 75 of 199
Thread: 1922 south bend 9'' lathe restore ......New stuff
  1. #61
    PA
    3,515
    i got my live center done, man is this thing nice to work with.
    i never did like dead centers and never really used them before....what a PITA
    i bought a bearing and pressed it into the body then i made a few different tips tonight.
    Attached Thumbnails Attached Thumbnails live center.JPG   live center tips.JPG
    WWW.HREATV.COM
  2. #62
    Nov 2002
    Kirkville, NY
    3,831
    So are you taking orders for trike parts yet, I could use some swing arm pivot bolts for the YT/YTM suspension kits...... lol
    It looks great! Now if you can't find it, build it!
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
  3. #63
    PA
    3,515
    we could maybe work something out.
    that kind of thing is about the perfect size to do on this lathe.
    tonight i also had a xr500 sleeve chucked up in my lathe to be shortened to fit in a 350 cly.......it's done but it was a little large....lol
    WWW.HREATV.COM
  4. #64
    Nov 2002
    Kirkville, NY
    3,831
    I will defiantly keep you in mind but it will probably be a couple of weeks. I have to finish drawing up the brackets and send the file to have them cut then check with the fabricator we use a work to see if he can bend some tube for me. It will probably be turned down to a 3/4" shaft with ends turned down and threaded to 12 mm.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
  5. #65
    Aug 2005
    Lockport, NY
    2,395
    Wayne. If you use that center, get some high pressure lube. You dont want to weld that guy into your work piece. McMaster Carr has it. Check it out. I highly recommend it.
  6. #66
    Oct 2007
    Grosse Tete, LA
    3,440
    hey swigin...if you didn't want to get the rod extended from powroll, but did want to run the xr500 cylinder, could you not only cut the cylinder, but have the piston cut as well...rather than run that spacer plate?
  7. #67
    PA
    3,515
    no lube needed man, well there is greese in the bearing.
    i seized a dead center in a work peice last week....thats why i made this live center.....the tip spins with the work peice.
    WWW.HREATV.COM
  8. #68
    PA
    3,515
    Quote Originally Posted by The Goat View Post
    wow goat, put the peice pipe down my man.....lol
    i think you wanted my ascot thread. your thinking backwards, the rod needs shrunk but yeah i do think that you can shave the piston dome and shape the combustion chamber of a stock head enough.
    just remember DO NOT get a xr500 12:1 piston
    being higher it just makes it worse
    WWW.HREATV.COM
  9. #69
    Aug 2005
    Lockport, NY
    2,395
    Quote Originally Posted by SWIGIN View Post
    Contrary to popular belief, it can be done. Just advice. Looking out for ya buddy
  10. #70
    PA
    3,515
    true, if for some reason the bearing would seize the tip would need lube.
    WWW.HREATV.COM
  11. #71
    Aug 2005
    Lockport, NY
    2,395
    Well mostly happens in high speed, DEEP depths of cut.
  12. #72
    PA
    3,515
    oh i see, tons of load on the bearing can cause the tip to stop.
    as im shure you know these old lathes spin slow compared to modern machines (to slow in my opinion) and large cuts are impossible.
    largest cut i can get on steel is .015 or so....and at that depth it looks terrible.
    the spindle to saddle speed ratio is off for todays fast cutting tips it seems.
    WWW.HREATV.COM
  13. #73
    Aug 2005
    Lockport, NY
    2,395
    Yes it is nearly impossible to obtain speed and feeds that carbide and high end tooling require on these old dinosaurs.
    you should buy your self a nice used book on ebay on cutter and tool grinding. You should be designing your own high speed steel cutters from blanks. They can be bought in 1/4 and 1/2 blanks.
    I dig thru some old docs and look
  14. #74
    PA
    3,515
    i used to grind them back in metal shop days and i have a few new blanks and a pile of HSS tips.....but then i cant use my cool tool holder...lol
    my indexable inserts are only rated C2 (brass aluminum) i got some decent ones coming from MSC.
    as long as i can make a half way decent looking cut in steel i'll be happy. and once i get a 3/4hp motor i'll be able to gear it up a good bit.
    WWW.HREATV.COM
  15. #75
    Oct 2007
    Grosse Tete, LA
    3,440
    lol....no peace pipe...I was actually thinking that your lathe would make short work of that.
