Results 1 to 9 of 9
Thread: idle help on 200s
    Nov 2008
    ontario
    1,055
    idle help on 200s
    my 200s has always started first pull and run really well with lots of power but it can't idle worth anything. i have played with the idle screw and when i get it to idle i give it gas and it takes a long time to get back down to idle, or and when it gets back to idle and runs for a minute or so its starts to slowly die if not given a bit of gas. this week i started it up after sitting for 6 days and it was idleing very fast but still started first pull. any ideas? thanks in advance
    proud owner of a trx300ex quad and an 85 atc 70
    Sep 2007
    100mi west of Chicago
    3,582
    If it starts idling really fast when you start it up you could have an air leak at the carb. My 185s sometimes acted like you are describing.
    Rob
    Apr 2008
    NW, IND.
    842
    Whenever it takes a long time to come down from idle, its the airscrew or leak. Clean carb and blow out idle jet and adjust back the way it was.Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Nov 2008
    ontario
    1,055
    ok i guess i will be checking for leaks next time, anything else i should be looking for?
    Nov 2008
    ontario
    1,055
    and the air screw what will adjusting this do?
    Apr 2008
    NW, IND.
    842
    It adjusts how much air/ fuel ratio that is being taken in the carb. I get my idle first and then turn airscrew in and adjust out to the highest rpm. Fine tune idle again. Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Mar 2007
    Texas
    5,045
    stock setting o nthe air screw (bottom center) should be 1+1/2 turns out.
    ________________
    https://www.mikesatvfix.com
    Nov 2008
    ontario
    1,055
    ok thanks oscar i guess thats a good start to know if something is buggered with the jetting or an airleak
    Mar 2007
    Texas
    5,045
    the needle should be in the center clip also. this is factory setting,s from there you can adjust up or down.
    ________________
