Results 16 to 30 of 39
Thread: more zinger mods for me
    Baltimore, MD
    6,088
    I don't really remember all the detials. But we used a yamaha moped. When you switched the main gear, yo had to switch the shaft gear too. If I remember it was the gear combo, not just the main gear of the moped. My buddy had it all figured out and he picked up the moped and I was helping. It's sort of like switching around the sprockets in a chain drive bike.
    OK
    5,450
    When removing the inner shaft for the pump. Do you just take out the whole shaft? I was going to leave the shaft with the plastic gear on it alone. But if I can remove it with no problems I will. I see your picture of the shaft, is it just held in by bearings in either engine case? And the shaft only works with the oil pump? Do you take off the gear that turns the shaft? If you do, do you have to put a spacer in its place?
    I have 3 motors to rebuild so I guess I just need to pull it apart.
    Thanks for the information I appreciate it. Also the connecting rod should have no side to side play right? I mean left to right play. All 3 of these motors have side to side play in the connecting rod. How do you measure the bore and the cylinder size to determine if you need an oversize piston? I see they have a .25 and .50 oversize set. Do I need to get a micrometer? And then covert the size to cm.'s ?
    Thank you, I have a long row to hoe with the 3 I have.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Front royal, va
    2,186
    you remove the shaft with the plastic gear too.and i removed the heavy gear on the countershaft as well. theres a circlip on the countershaft that holds the clutch in place, but if ever came off, i made that spacer so it wouldnt go "in" to the cases and destroy it.
    the rod is supposed to have side to side play. i dont have a book to tell you what it is, but it is NOT supposed to have up/down play.
    the piston is only made by yama that i have found. when you look at the top,it will have an arrow and it will say nothing for stock bore, .25, or .50 near that arrow.hope that helps you, nathan
    Front royal, va
    2,186
    got a lead from another member that this thing might be a direct bolt on a zinger. its for a 45mm piston, and has the reed block directly on the cylinder!!!then ill have to have the cases welded up and an intake made.
    damn, this is going to get expensive!!
    Attached Thumbnails Attached Thumbnails big bore 204cc zinger kit stroker.jpg
    Jun 2006
    Willow, Alaska
    1,340
    What size is the stock piston? Is that a YZ80 or a PW80 cylinder?
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Front royal, va
    2,186
    Quote Originally Posted by Nick_R_23 View Post
    -Nick
    i honestly dont know what the stock size is, maybe 42mm???? the cylinder in neither, its an aftermarket one like esr or ct. its for a motorcyle type is all i can say!
    N.E. Ohio
    2,002
    HUSH HUSH TOP SECRET anymore probing questions will be LMAO
    Jun 2006
    Willow, Alaska
    1,340
    Haha ok I will keep quiet now!!
    -Nick
    bandito90's Avatar
    bandito90 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    284
    It's for a Chappy correct?They were fun bikes.Should make that zinger really move!
    Baltimore, MD
    6,088
    I'm not sending out any more pm's on this! LOL
    bandito90's Avatar
    Pa
    284
    Well when you scrolled over the pic it kinda told you what it was.
    Front royal, va
    2,186
    Quote Originally Posted by bandito90 View Post
    what are you talking about?? it doesnt say that when i scroll over it.
    Aug 2005
    HI
    1,575
    204cc stroker?!@>!>!@
    Rest in peace Rex Carlson
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    Just wondering, why do you want a fast Zinger?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
  15. #30
    Front royal, va
    2,186
    Quote Originally Posted by LonesomeTriZ View Post
    sorta like my signature, going to have" the fastest zinger on the planet... make a note".
    and NO ONE has one built like this one im building.
