Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: more zinger mods for me
    Front royal, va
    2,186
    first thing i did was scrap the pump, shaft and a 1/2 pound gear, and a plastic gear as well/.
    then i put different clutch weights in it..there the little rubber things inside the clutch.
    with the gear gone in the trash i made a spacer, just incase the circlip came loose.
    jb welded the pump shaft hole up, now im waitnig to sand it flush..
    and im going to lighten the "drum" i "hear" i can take half its weight off!!!!
    Attached Thumbnails Attached Thumbnails 000_1490.JPG   000_1493.JPG   000_1497.JPG   000_1499.JPG
    Front royal, va
    2,186
    took it for a ride...WOW
    higher "stall"..... revs SO much faster with all that extra weight off the main shaft feels so much quicker, but more of a lightswitch powerband now. it hits like the banshee does.im going to try a different weight in there next week, to fine tune it. tomorrow its back apart to lighten the drum..
    found out you can put a "shifting" tranny in there, now i got to hunt one down.. 3or 5speed, that is the question.
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    What other mods are you performing? I want to do some stuff to my son's Zinger when I get home.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Baltimore, MD
    6,088
    I had heard you can get a shifting trans, but never knew the details. Maybe you can elaborate on that. Have you found your yamaha moped yet?
    That's where the better rear gears come from. Your modding this zinger the right way. Nice job.
    Jan 2005
    5,301
    I to would like ot hear more about that.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Front royal, va
    2,186
    louis, im modifing the piston. porting the cylinder,(but not the cases yet)shaving the head, lighting the flywheel , getting a rep. pipe builder the build a pipe $$$$$. carbon fiber reeds, pw80 carb, clamp on filter.and what i ve done iside so far.
    veal, i havent found "it" yet, but ive been looking hard for the past week. they make them run around 40ish or so.the trans stuff is going to be a hard find, they only made them a few years one or two i think. ill pm you later on what you need to find.
    Jan 2005
    5,301
    I would like very much to know how it runs after all this is done.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Front royal, va
    2,186
    completed block off, and parts removed. i also removed the skid plate and the oil tank. 2 lbs shaved off so far, and if the oil tank was full of oil, thats another 1 lbs off.that little gear is HEAVY for what it is.
    Mar 2005
    overton, PA
    5,257
    git it lil ragggggg
    Jan 2005
    5,301
    Thanks for the photographs. My son is going to be ready for a little more speed when I get home.
    Do you have any more information on the carb you are using?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Jan 2004
    Palmetto,Florida
    2,300
    I Used the 20mm carb off the pw80 versus the 16mm stock carb. , hey nathan ... bring that thing with you next week !!! we can go git a couple of allum baseball bats and make another pipe !! LOUD tho .. i'll git the skill saw out with the carbide blade on it !
    "07" DR650 Suzuki Dual Sport
    Baltimore, MD
    6,088
    If you are redoing your intake, I would suggest using electrical aluminum conduit and a little artful cutting and welding. I would recommend a straing shot with the intake run as it will help with better direct airflow. You can angle your intake anyway you want if you are building from scratch and tig welding. You can find that phenolic block stuff too to make it look just like the factory stuff if you look hard enough. A little time with a die grinder or a very small router bit and you will have yourself a very nice custom reed block. If you have a nice set of small router bits, you can round over your reed inlets a little and I wouldn't make the corners of your reed block square either, those rounded too would be nice but just a personal preference. Once you source your moped, a little finesse is needed with the press to get your gears off and swapped over. Now if you are really crazy, then you will source out a different cylinder and head. A cylinder with a proper reed block in the back of the cylinder is what you are looking for. I forget what cylinder we used, but it was late 60s or early 70s. The hard part isn't the cylinder, it's the welding or your engine cases and then the drilling and the tapping to get your cylinder all square. Once you get all that in place, yo have to make a plate to block off the stock intake and then lots of porting and polishing and massaging in general will be needed. Don't throw your piston away, since you will have to par the weight down on the bigger piston to the comparative weight of the yt piston. And even though I haven't seen one in lots of years, there were even stroker kits available for the yt60. Also I know of a guy that could probably hook you up with a custom made expansion chamber. He makes lots of them for many different machines. It won't be cheap, but it will be your only real bet to get the most performance out of your engine. Try sourcing go kart rims to save you weight also. Go kart tires will help you alot. I would seriously think of bumping up my compression and running alcohol. Also you may want to go back to the stock flywheel weight pieces since your engine is revving up alot faster. Remember, don't rush the press. Best of luck. I'm digging this big time. Now who was it on here that had the yt60 with the suspension?????
    Lewiston, N.Y.
    1,477
    This is getting serious. I have really no idea about 2 strokes and really dont know what all this means but i am enjoying reading this thread big time!
    Jan 2005
    5,301
    I am as well. I am getting a lot more ideas than I started with.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    250rulzes is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2004
    TEXAS
    228
    Veal Monkey,
    These are some seriously sweet mods! I do have a question. I'm in the process of getting the rear gear from a QT50. By the looks of the gear it has more teeth than the YT60. Since the QT has a larger tire, wont this make the YT wheelie happy sacrificing top end speed?
    So if you put a small tire on a QT, if it was possible your top end speed would suffer and you would have a wheelie QT?
    Shed some light...
