Thread: 83 big red mod!! Need ideas
    Feb 2009
    Oregon
    Question 83 big red mod!! Need ideas
    So I just bought an 83 200 and am starting its build.. I want to eliminate the rear storage box and retro fit some other fenders to it. Also does anyone make a piece to cover the void created by removing the "trunk". I want to go with something smaller and flater.. not sure what I should look for.. Also Im goin with a simple look, I eliminated the start/light/engine cut, bar assembly as well as the barmount choke and relocated the ignition and created a waterproof housing for it, Which I located under the tank on the frames down tube.
    Mar 2007
    Texas
    5,045
    200m is the only thing that will got the 200e/es big red.
    here's a question, why did you even buy a big red then if your going to trash it? the point if a big red is a utility trike. if you wnat a sportster then get a 200s or 200x. heck i got a fariley well redone 84 200s that I'd sell ya for $750. then you can seel yout red and make msot fo that back. then you got a sport style trike instead of trashing a good utlilty trike that was ment for work.
    ________________
    https://www.mikesatvfix.com
    Jun 2006
    Willow, Alaska
    1,337
    +1 to that. If you bought that Big Red to modify then you will be pretty disappointed. About the only mods you could do to it would be a larger exhaust, 200x cam, and change the gearing (which even then wont give you many choices). With the mods you are trying to do, it sounds like you would be happier with an ATC200, 200s, or 200x. Look into one of these, they sound more like what you want.
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Jonpin's Avatar
    Jonpin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Melbourne Florida
    333
    yea sounds like alot of work for nothin
    05 Kingquad 700 85 200x 85 250es 85 350x
    85 350x rider project 85 350x (project) watch the progress here http://3wheelerworldforums.com/showthread.php?t=85959
    Goin to prove you can polish a turd "so far it takes a lot of cash to buff that brown out'
