Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: what sealant do you use to reseal your cases?
    Charles Town, WV
    1,316
    Hondabond HT--It's used at manufacturing time on Honda (automobiles) Manual transmission halves (among other things). That's all I used on anything that didn't require a "solid" gasket for over a decade while working for Honda and in my own shop.
    I have 100% level of trust in Hondabond (if surfaces are prepped correctly and hondabond is applied correctly)
    http://www.hondapartsworld.com/hondabondht.aspx
    Item Number: 08718-0004
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    howdy, i use the exact same stuff. I have had the same can for 3 years and its still half full. Excellent stuff. I also have used 3 bond...it works great too..if you can find it.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by timex69 View Post
    Nice to know someone else on here uses the same stuff and likes it. I know most all my local friends have switched over to it.
    Howdy
    Mar 2007
    Texas
    5,045
    i 2nd hondabond! we use that stuff on 500+hp drag civics.
    ________________
    https://www.mikesatvfix.com
    Aug 2004
    Ab Canada
    4,368
    515 loctight works good, its a anaerobic sealer so it will only harden in the absence of oxygen (ie bolt the cases together) i like it, no mess, only takes a thin film to work, and it will move with the case's which is nice on larger inline 4 motors ect.
    1985 Tri-Z-
    Apr 2008
    NW, IND.
    842
    Yama bond or three bond... Good stuff!!!
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Apr 2007
    Three bond is the best but I prefer to use no sealant or only very little on problem areas. When I break a factory sealed case there's never any visible sealant.
    Airfoolers RULE!!!
