can the hi/lo subtrans be removed from a 200e so that just a regular drive sprocket can be used?
im curious, why you would even want to do that?![]()
lol well not to long ago i got my autox together and at the apex of a hill climb the cam chain snaped........... that leavs me with an 82 200e but because of the sub-trans it won't fit in my x frame
I thought the frame could be dented for the Hi/lo as well? I think someone else got a 200e motor to fit.
Romoving the hi/lo would then require changing the output shaft too, aka a lot of work.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
swap the top ends
the topend is fine....the only way i know of to replace the cam chain is to split the case. Fox I'll try searching that would be great if it's possible!!! let me know if you can think of any key search words to find it.
you can change the chain by removin the flywheel, heck i have a good used cam chain you can have
Rides
85 ATC350X
85 ATC200X
Yeah you don't have to split the case to change the cam chain. The left cover behind the rotor comes off and the cam chain is right there. You do have to remove the cam so you can drop the chain down but you don't need to remove the whole top end either.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
thanks I'm on my way out to try this I'm in omaha and it looks like a snow is do in tomorrow noonish there sayin 5" to 10" hopefully I'll have a soft ride for my rear lol!
