Took my 350x out for a little ride. It was running great except my oil cooler was still leaking. Got back to the house and put it away. Later went out to clean out the shed. Moved it outside for a few. No wet spots on the floor. Shed all cleaned out so I decided to rip around on the 350 again. Walk over to get on and start and there is gas pouring out of the bottom of the carb. I turn the petcock off and it stops. Check drain screw and bottom nut and there tight. Turn petcock on and it starts pouring out of the drain. I pulled the carb off and everything looks clean and no clogs that I can find. Is it time to by a carb rebuild kit or should I rip it apart and clean everything. Never had it apart before and never had a problem.
Any suggestions would be great.
....it may stop it...
