Results 1 to 15 of 17
Thread: 250R Carrier bearings....what did I get into!? #$%!!!!!
    saleen_n_around's Avatar
    saleen_n_around is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Clarksville, TN
    426
    Well, I got motivated yesterday to go pick up a set of bearings at my local distributor and tear into my 85 R last night.....got better the further I got!
    Meet my two new best friends....
    I need a bigger table, this is what I normally build Z50's and ATC70's on!
    The bearings I got at my local bearing supplier were Japanese KYK bearings and the number on the box is 6908 2rs c3 sr12 and the number on the seal is TCM 62x52x8. Got it all apart and will clean it all up and inspect everything in the morning...
    After cleaning everything up, I have one broken, one stripped sprocket bolt, the splines are starting to twist on one end of the axle, the seal surface on the sprocket hub is chewed all up, the swingarm bolt turns but won't come out, the swingarm is cracked at the bottom side of the ears on the side that has been welded once, and the bearing carrier is worse off than a 3 legged dog, blind in one eye with a bladder problem!
    So I need to find an 85 bearing carrier, I need the large circlip for the brake caliper side and the axle will have to stand the test of time.
    Or I am just going to brake down and do this!!!!
    Ron Turransky
    1986 250R - Psycho Virgin....
    1985 250R - Venom....
    1984 250R- Resto
    1996 TRX200D - Workin' for a livin'
    Oh, and a Harley...
    May 2007
    Coshocton, Ohio
    1,815
    I would go with the update.
    Appalachian American Racing
    the home of
    Apr 2008
    NW, IND.
    842
    Time for a new carrier. There not getting any cheaper. I've gone thru 4. I shattered one in P.A. one time, came out in peices. From jumping to hard!! I would REBUILD the old. Had one similar. We ended up drilling thru and making a hill side washer(wedge shaped). Wirefeed that will take care of that crack(clean that crack!) in the swingarm. Or find another swing. Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Aug 2005
    Lockport, NY
    2,395
    Update that sucka!
    Done deal.
    Jan 2008
    Clarksville, TN
    426
    I spied that one on ebay, we'll have to see what it tops out at......
    Ron Turransky
    1984 250R- Resto
    Oh, and a Harley...
    Oct 2007
    SouthShore - MA
    653
    Ive seen them go for 250 - 300$. Now would be a great time to buy one just to have for future considerations with the down market everything is cheaper.
    MA
    385
    At least you have an 85 and can find swingarms and bearing carriers on ebay. I can't find crap for my 84 and I need the same parts!
    Dec 2007
    Quebec,Canada
    1,014
    I simply rebuilt my bearing carrier,I built 2 steel bushing to replace the place were mine was cracked (like yours) and press it in the carrier.I think I will never have the change it forever...
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Heres a duel row bearing carrier for about 170$
    http://cgi.ebay.com/ebaymotors/HONDA...2em118Q2el1247
    Lonestar carrier with 1 yr warrenty 180$
    http://cgi.ebay.com/ebaymotors/Lone-...2em118Q2el1247
    I bought a Boss Racing carrier for my X cuz my carrier was beatup worse than yours, and I think it was 99$ or so, so far I'm happy with it. I didnt see any on ebay for the R's tho.
    TF 07,08,09,10,11,12,13,14!
    Somebody was selling no name loaded carriers for about 100$......
    BUT, I'd upgrade it too if you can win the parts cheap!
    I don't even own an R but I won a 06 swinger for .99c, carrier for 19.99 and an axle with hubs for 60$. The caliper is like 50$ brand new so thats not an issue.....
    Oct 2007
    Grosse Tete, LA
    3,441
    Update. One thing to point out is that the 450r axle is a little shorter than stock. It looked 3-6 inches shorter than the 350x axle.
    Mar 2005
    overton, PA
    5,257
    if memory serves me correct the 250r axle will work in the 450 carrier but i swaped the entitre rear end om my 250r and alli had to do was make a set of bushings.
    Jan 2008
    Clarksville, TN
    426
    I know it's shorter, what I need is the magic combo for the shock and linkage.....Is it 250R shock and 450R linkage, I also heard a 300EX shock works well, but I weigh around 240 so that is the question I have...
    Ron Turransky
    1984 250R- Resto
    Oh, and a Harley...
    Oct 2007
    SouthShore - MA
    653
    Jul 2006
    400ex shock is the best, with the 250R linkages on the 450R swinger
