Results 16 to 30 of 41
Thread: New trike owner (yamaha). Help?
    Feb 2009
    Saskatchewan
    28
    Lol yeah, I'll be grinding those off next time I have the grinder out.
    How easy are 175 front forks to find? I definetly want some front shocks on this thing.
    1982 Yamaha 175 Tri-moto (parts)
    1983 Yamaha 175 Tri-moto
    198? Yamaha 125 Tri-moto
    1986 Honda 250 Four-trax
    Nov 2008
    Coon Rapids, MN
    956
    Looks like you got your self some decent trikes on your hands, you going to love building them up to there former glory. Also if you need parts post up a wanted ad in the ATV classifieds I am sure someone is got what you need laying around and if you need help getting them to run let me know and I will try and help the best I can. By the way there a blast to ride especial when they got front suspension.
    Alex
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Feb 2009
    Saskatchewan
    28
    So I got the 125 started (it was slippery so putting it in first didnt work. So we push started it in 4th (yes push lol), ran it for a few minutes, then I didnt adjust the choke and it stalled. Couldnt start it after.
    And the 175 is missing more parts than I though.
    So far my list is
    Need: choke cord, brake handle, steering ball bearings, pull starter, foot pegs, and whatever to make the engine run.
    Could use: Seat cover, brake cables, handlebar grips (fox), Tachometer (anyone know the redline?)
    Want: Front shocks, new handlebars (fox?), paint job.
    I'm a big fan of fox racing equipment, but have not been able to find what all they make that could be put on a trike. Does anyone know, or know of an online catalog?
    May 2008
    Juneau
    605
    you should pit the two bikes together and get one nice one
    3 wheelaholic
    ATC200/CR480 custom
    1984 atc250r near mint
    wr450f trike on the way
    Trizinger for my sons
    Feb 2009
    Saskatchewan
    28
    No need, the 125 is a good trike, minus the starting/runing problems. Doesn't really need anything other than that.
    And he 175 is my little project, gonna build it up beyond stock. Turn it into something I can race around with.
    Nov 2008
    Coon Rapids, MN
    956
    Mine would do the same thing in till I discovered That the carb was getting clogged with very fine particles of sand, So I put a fuel filter on it and cleaned the carb again and it solved my problem also set the carb air/fuel mixture screw to 2 1/2 turns out from closed and If you got any more questions about specifications I own the repair manual also have you tried checking compression on it, it might need to be rebuilt.
    my favorite link.
    http://www.3wheelerworldforums.com/s...+175+beginning
    Check these PK aftermarket parts ads out.
    http://www.3wheelerworldforums.com/s...ight=pk+racing
    and check this one out to
    http://www.3wheelerworldforums.com/s...ad.php?t=64931
    My feedback.
    My album
    Feb 2009
    Saskatchewan
    28
    Thanks for the links. I saw the rear suspension one already, and I am very interested in trying to find a kit like that after I get back from paris and have some cash.
    And my 175 came with a repair manual. Would the 175 and 125 manuals be closely similar?
    Nov 2008
    Coon Rapids, MN
    956
    It should be pretty close except for the carburetor,cylinder,head,piston and exhaust other then that, they use the same parts in the lower end and on the frame.
    My feedback.
    My album
    Feb 2009
    Saskatchewan
    28
    Okay thanks man.
    I noticed the exausts are crazy different. is the 175 alot better? is there one i could put on to get some more hp?
    Nov 2008
    Coon Rapids, MN
    956
    Yeah here's one I seen on ebay even though it says for the 125 and 175, They do not interchange because only a 175 pipe will fit on a 175 engine and only a 125 pipe will fit on a 125 engine, If I was you I would put all my money into the 175 to get it running again.
    http://cgi.ebay.com/ebaymotors/NOS-Y...Q5fAccessories
    My feedback.
    My album
    Howdy's Avatar
    Celina, Ohio
    10,079
    Too bad you don't live close to me. I would hook you up with a bunch of parts for the 125 & 175 cheap. Shipping would be a killer though.
    Howdy
    Feb 2009
    Saskatchewan
    28
    That would be sweet, but yeah it would be esp bad getting it over the border. But thanks anyways man.
    And yeah most of my money will be into the 175, the 125 doesnt need much money, mainly just time.
    Went to go order the steering ball bearings, $25 for the top an bottom, argh. Gotta see what ones I really need before I order them
    Nov 2008
    Coon Rapids, MN
    956
    Here's the links I use to find parts on ebay, you can try using your own this is just what I use.
    175 parts.
    http://shop.ebay.com/items/_W0QQ_dmp...+125&_osacat=0
    125 parts
    http://shop.ebay.com/items/_W0QQ_nkw...romZR40QQ_mdoZ
    My feedback.
    My album
    Nov 2008
    Coon Rapids, MN
    956
    Have you had any luck getting your trikes running again?
    My feedback.
    My album
  15. #30
    Feb 2009
    Saskatchewan
    28
    Tried the other day to push in 4th again, couldnt get it to turn over fast enough. And not enough energy to try again. Went home, thought about it, and I might have been in 3rd last time and thought I was in 4th, which would be why it fired then.
    Might go try it in 3rd if I have the energy to push the thing this week.
