Results 1 to 15 of 20
Thread: What do you guys think of this engine color?
    Brad200X's Avatar
    Brad200X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Will County, IL
    357
    Had a can of grill paint that just said black, so I gave it a shot and this is how it came out. I like it, but I'm not sure if I'm sold on it. Opinions?
    Rides I own:
    '85 200X(old smokey)
    '81 ATC250R(Bassani pipe, Wiseco piston, Vesrah rod, and AMS offset rims)
    '84 KXT250 Red(the new money pit!)
    '96 KX125(FMF pipe, Boyesen reeds, One Industries graphic kit, etc.)
    '85 KX125(vintage racer. Technically it was a practice bike)
    '78 DT400(the lone Yamaha)
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    IMO its not black enough, almost looks like a grey in the pic.
    TF 07,08,09,10,11,12,13,14!
    Feb 2008
    (southern) Wisconsin, USA
    974
    The color looks good for a low buck job. I've had good luck with the "grill" paint on OEM exhaust stuff. The silencers and pipes I've used it on are more for show though, and not run very much. It may not last very long with normal riding abuse, but is a lot more economical than a full powder coat job. Looks good to me. I think it'll look better after installed. A semi or gloss black might look a step closer to OEM, though. Just my 2 cents?????
    Brad200X's Avatar
    Oct 2008
    Will County, IL
    357
    Yeah I definitely would have preferred a semi or full gloss black, but this motor came out of a first gen R, and I'm not painting it red, so it isn't gonna be a stock look anyway. It looks a little bit darker in person, but its still VERY gray. The motor is the main focal point on a bike, so I want to do it right. The rest of the bike is a metallic red/maroon color so I don't think it'll look too bad.
    Rides I own:
    Oct 2007
    Grosse Tete, LA
    3,440
    have you thought of hitting it with a high temp clear?
    Brad200X's Avatar
    Oct 2008
    Will County, IL
    357
    Quote Originally Posted by The Goat View Post
    Thanks a lot Goat! You reminded me that I had a can of VHT clear. It isn't dry yet, but it looks really good. It may be a little grayer than if I used semi-gloss in the first place, but its glossy, and that all I really care about. Pic to come!
    Rides I own:
    Oct 2007
    Grosse Tete, LA
    3,440
    sweet, can't wait to see it.
    Apr 2008
    somerset ma
    1,822
    It doesn't look that bad, why be like everybody else? just my .02
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Brad200X's Avatar
    Oct 2008
    Will County, IL
    357
    Here's the promised pic! Sorry about the tardiness I couldn't wait to stick it in the frame.
    Rides I own:
    Oct 2007
    Grosse Tete, LA
    3,440
    that thing is ridiculously shiney. and I think the gray underneath is giving it a more smokedmirror look than the black.
    Mar 2007
    Ontario,Canada
    35
    Use Engine paint used on big block
    _________________________________________________
    1984 200es Big Red.............1985 250es Big Red
    Sep 2007
    Quote Originally Posted by coteya View Post
    i used that stuff on a pipe i had and it burnt off after about 10 min of it runn after i let it dired over night
    Oct 2007
    Grosse Tete, LA
    3,440
    can't use it on the pipes on a four stroke...can use it on the block of a 2stroke.
    those airRs don't get that hot.
    Brad200X's Avatar
    Oct 2008
    Will County, IL
    357
    Yeah it came out pretty good. The crappy picture quality doesn't do it justice. It would have come out better if I hadn't run out of paint on the initial coat, but its at least in spots where you don't notice it. I think its glossier than the shift lever I painted gloss black earlier.
    Rides I own:
