Results 1 to 10 of 10
Thread: 70 question......
    knsmodels's Avatar
    knsmodels is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2005
    Bucks, Pa
    318
    70 question......
    carb on my sons 70 is dripping out of the overflow hose when the trike is not running.....it starts right up and is running fine all except this problem any ideas??? also I put new rear tires on it but they both have slow leaks should I try putting some fix-a-flat in them to try and seal them up or do I need to put tubes....Thanks.....
    86 350X
    86 200X (son's)
    86 250sx (daughter's)
    84 70/125lifan
    68 SS Chevelle
    72 4X4 Chevy Truck
    Click to see what I do
    Long Beach, Ms
    65
    It could have something on the tip of the needle, but most likely the needle has a groove in it letting fuel by. I would install a carb kit and let her eat.
    Feb 2008
    Pennsylvania
    2,306
    Bowl float may be stuck. Tap on the bowl of the carb to see if it stops
    '86 Honda Big Red 250es
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    '00 Honda Trx 90 (sons ride)
    atc70/110
    knsmodels's Avatar
    Dec 2005
    Bucks, Pa
    318
    float seemed fine when I took it apart but I will check that next time out in the garage.....
    86 350X
    86 200X (son's)
    84 70/125lifan
    68 SS Chevelle
    72 4X4 Chevy Truck
    pa
    137
    when i put new tires on i put a wire wheel on a drill and cleaned the wheels really good where the bead of the tire seats and also wire wheeled where the O-ring goes. you could also put some gasket sealant on the O-ring. if the O-rings are in bad shape you could always replace them. i didnt have to get a tube. one more thing you could through in new valve stems if you already didnt.
    Dec 2002
    deer park, texas
    2,336
    You probly needed to clean the mounting surfaces before mounting the rim. Do not put fix it flat. The right way is to break them back down and clean them up. The cheater way is to add slime.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    OHIO
    2,857
    Would not use slime. The rim surfaces must be spotless, use power wire wheel. Check outer rim bead for burr's or dent's and file if needed. Just pull out old stem and use new, couple of buck's. I use new o rings and a little blue rtv silicone to seat them. Make sure your gasket is centered in the groove. Let silicone tack up to do this. As for carb, may be float needle seat worn or float height. 20mm or 0.79 is the setting from body flange to uppermost edge of float with carb inverted. Bend the float tang to do this. Good luck, love the 70's man............ madtiken to all
    knsmodels's Avatar
    Dec 2005
    Bucks, Pa
    318
    thanks for the replys.....I will try these things out over the weekend and let you know how I make out......
    86 350X
    86 200X (son's)
    84 70/125lifan
    68 SS Chevelle
    72 4X4 Chevy Truck
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    My 250sx was sitting in a river, front tire was still good and this is how:
    Wire wheeled all rust off where the bead sits, put some bead sealant on it and then over inflated the tire to pop the bead.
    Tire center did the valve stem and bead sealant for free.
    Nothing to ride... for now
    Jun 2006
    Utah
    91
    My 70 leaked out the overflow tubes too. I rebuilt the carb and was ticked it still leaked. Ended up being the vents on the gas cap were sealed off. Tank would sit in the sun, air would expand in the tank, force it down into the carb and out the overflows. New cap from Dr ATV and no more probs.
