Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: all this for $150
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by leevarnado View Post
    well a few hours ago i took the topend apart and measures the piston and jug.the piston needs replacing and the jug needs honing or boring.i need to know what size piston im going to need and how much to bore the jug.heres the pics with the measurements.Attachment 74987
    Attachment 74988
    Attachment 74989
    You can't properly measure a cylinder with just a set of calipers. You need a set of these: http://cgi.ebay.com/ebaymotors/Comp-...QQcmdZViewItem
    You need to measure multiple spots to check for out of roundness, taper, ect. If you take the cylinder and a manual with the specs for it to a local shop, they can look at it and tell you what it needs.
    Howdy
    Mar 2007
    Texas
    5,045
    you need the 65.5mm piston, that's the next size to bore to. your stock bore right now. i think the weisco 200s piston will work in it, which means more power! 10.5:1 comp vs the stocker 9:1. you jsut run super unleaded is all.
    ________________
    https://www.mikesatvfix.com
    louisiana
    1,499
    oscarmayer
    Quote Originally Posted by oscarmayer View Post
    hey man can give me a step by step on how to correctly bore my cylinder.i have an wiseco 65.5 mm piston that im going to use.this will be my first time doing a bore job and would like to do it correctly.im going to the parts store this weekend to buy a cylinder gauge and a honing tool.if you dont mind share some info.
    louisiana
    1,499
    think im going to save the wiseco piston for another project.i have a piston with low hours out of a spare 200x engine(cam failure).its .25mm over.this is what it looks like(http://cgi.ebay.com/ebaymotors/Honda...essories)heres my question is,what would be a good set of rings to use with the .25 piston,would it be
    1.the .25mm rings from service honda for $35
    2.this from ebay.http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
    3.or this from ebay.http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
    or is there a better set of rings made for the piston i want to use.
    Signature pic removed,becuase of no helmet.
    louisiana
    1,499
    help with rings
    im needing help selecting a set of rings.info should be in above thread.
