Results 1 to 15 of 15
Thread: how to:set timing
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    how to:set timing
    me and my friend just put in a new timing chain in my 81 atc200 but we cant seem to get it timed correct. can anybody give a in depth guide.. at the moment we have the intake vavle going down then a pause then the exaust vavle goes down
    Apr 2006
    Crestview, Florida
    2,429
    Rides
    85 ATC350X
    85 ATC200X
    Cornwall
    344
    no manuals for my bike and the one for a 200s dont really describe howto set the timing..
    May 2007
    Orange County, NY !
    1,672
    There is overlap between the valves. That is the point at which both valves are slightly open to together, but one should opening, while the other is closing.
    There should be marks.
    The timing mark on the flywheel, and the mark on the cam gear should line up with something.
    Or you could buy this:
    http://www.themotorbookstore.com/honat20019.html
    Sep 2007
    100mi west of Chicago
    3,582
    This one has an extra chapter for the 185s/200:
    http://www.mediafire.com/?dmijwwcmidw
    Rob
    Apr 2006
    Crestview, Florida
    2,429
    Ok, here goes. Remove the upper plug from the left side cover and turn the engine over until you see the T mark. Then remove the chain and line the dot on the cam gear with the triangle shaped spot on the head above the opening. Reinstall the chain. The cdi should have a line on it that lines up with the same spot as the cam gear. Double check you marks on each part
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2004
    OH.
    2,487
    Quote Originally Posted by Erics350x View Post
    Don't forget to pull the spark plug and make sure that it is on TDC (top dead center, when the piston is all the way up). The t-mark will show up when the piston is on the bottom too and you'll be 180 deprees out. Also make sure the cam gear is on correctly.
    T-mark in opening, piston at TDC, mark on cam gear lined up with mark at top of head, cam lobes down and valves closed.
    Cornwall
    344
    will the plug still give good spark if its not timed rite:?
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Quote Originally Posted by acidburn View Post
    Yes, but it will fire at the wrong time.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Apr 2006
    Crestview, Florida
    2,429
    Make sure the pin in the cam that turns the rotor didn't fall out.
    Rides
    85 ATC350X
    85 ATC200X
    Cornwall
    344
    ok so it is perfectly timed ! but the only problem is when u hold the throttle it revs cuts out revs again etc. any help!?
    Apr 2006
    Crestview, Florida
    2,429
    Have you tore the carb and petcock apart and cleaned them? What about valve adjustment?
    Rides
    85 ATC350X
    85 ATC200X
    Apr 2004
    1,528
    Had a similar problem with my big red. Try adjusting the fire timing by turning the plate holding the pulser coil. There is a mark on the flywheel to adjust it.
    Cornwall
    344
    my buddy messed around with the fire timing it doesnt cut out half way the only slight problem is it lightly cuts out before i have to shift?
    its got tuns of balls now but im sure its not supose to do this.
    Nov 2004
    OH.
    2,487
    I'm with Erics350X. Clean the carb good and adjust the valves and timing chain tensioner.
