Results 1 to 11 of 11
Thread: 250r frame height?
    Dec 2002
    Kansas
    2,387
    250r frame height?
    Can someone give me some measurments? I would like to the know the hieght of your frame from the ground to the bottom side of your frame, with suspension fully released as high as it will go and while your setting on it.
    Billy you made the comment once that yours was really high, can you give me your measurements also?
    I'm working on putting a no link set up on mine like ktm, cdale run. Trying to get measurements before I start cutting it all up.
    I had the RIGHT to remain silent, I didn't have the ability!
    Sep 2003
    Elizabethtown PA
    1,581
    you dont have to cut up your frame for a no link set up. you just need the rite swinger and aftermarket shock
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Mine was like 11 3/4 with the way the shocks WERE setup, Loaded, (without me on it, just its own weight) I'm told by one of the shop guys @ WRC that they shoot for 7 inches optimal clearance on the tracks around here unless its sand or something that ruts up really bad and needs more.
    I've got mine down to bout 9 1/4 now. I can't go any less or the spring cups on the bottom of the shafts will fall out when the shocks are unloaded from lack of tension on the springs. Measure right behind the A-arm mounts in the front, and in front of the foot peg mounts. 1/2 difference between those 2 places is OK depending on which way you want your weight transferred (Low in the back for more traction, or low in the front for more steering traction if the front end is pushing from what I understand)
    SCEADU's Avatar
    SCEADU is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Atlanta, GA
    330
    DOh!!!
    I just sold a Fox shock for a non link 250 R on Ebay today. I still have the swinger and a skid plate for it if you are interested.
    Dec 2002
    Kansas
    2,387
    Yes very interested? How much $.
    SCEADU's Avatar
    Feb 2008
    Atlanta, GA
    330
    The swinger looks to be the older Steel type. The skid plate is alluminum. I just checked and who ever bought the Fox shock is from Kansas. Did you just win a Fox shock on Ebay?
    Gimme 20$ and shipping and I can send you the swinger and skid plate.
    Dec 2002
    Kansas
    2,387
    Yes I did rear and 2 fronts and coolant bottle.
    SCEADU's Avatar
    Feb 2008
    Atlanta, GA
    330
    Dec 2002
    Kansas
    2,387
    Nope thats not me.
    SCEADU's Avatar
    Feb 2008
    Atlanta, GA
    330
    Ok..
    SOmeone else in kansas won it lol. Gimme a zip and I will let you know the shipping on the Swinger and Skid.
    Dec 2002
    Kansas
    2,387
    sceadu check your pm's
